Re: [Nagios-devel] Is nagios core extendable? (fwd)
Sorry, my mistake.
Here is one row sample output:
NMP is tag (Nagios Mysql Procss), process is tablename, timestamp, hash=
_code, row size, host_name/crc, body.
NMP:process;1239115837; 24883; 323;skirit69.ics.muni.cz/2086;=
name/4:varchar(128):init;login/4:varchar(40):root;uid/1:int:0;realName/=
4:varchar(128):
root;pid/1:int:1;state/1:varchar(2):S;ppid/1:int:0;rss/3:int:424;vss/4:=
int:6120;path/20:varchar(255):variable uninitiated;cmdline/18:binary_co=
de:init [2]..........;+;
--Lada
> ------------ P=F9vodn=ED zpr=E1va ------------
> Od: LadislavHavlik
> P=F8edm=ECt: Re: [Nagios-devel] Is nagios core extendable? (fwd)
> Datum: 07.4.2009 16:54:55
> Hi Andreas,
> well I must describe more information about solution:
> in our concept is Nagios - only part; "collector" for a lot of values=
, which are
> send (as passive tests, or active test) from each node =3D we are dis=
tinguish
> between sensors and tests(test poduces only state and "easy" plain te=
xt.
> Sensor produces more structured information that can describe any
> mysql table(s) (it is META data and data selfs), I may append one row=
=3D
> output from sensor, that contain "pre-evaluation":
> It could be good.
> Yes, I don't need defined mysql tables (in advance time), each sensor=
defines
> table
> self and Nagios can create table if not exist and saves data into tab=
les... One
> note:
> first is update if operation is "failed" then insert.
> One format in structured format is binary_code.
> Yes, but event broker module does solve problems such is cumulative l=
ogs (we
> have
> service data =3D meta data and "data". Where I can read more about ev=
ent broker
> developing
> (I have only "halloworld module", but I need more info, about modules=
design,
> how connect
> to nagios, possibilities...more :))?
> Well, I can go back, from hard source code programming and modify to =
module
> programming,
> I think that is probably better solution (maintainability).
> Thanks
> Lada
> Sample one row sensor output code:
> > You can do that, provided the resulting fork is still licensed
> > under GPL, the same as Nagios is today.
> > > 1. direct saving results into DB (not by using NDO etc..., but di=
rect -
> ASAP
> > but refllex possibilities
> > > DB and work node ~ such is latency, IOWait, busy Waiting, timeout=
s,
> etc...),
> > That would be stupid for a lot of reasons, not least of which is
> > that you'll have to maintain it separately forever and ever.
> > > 2. "predictive - modul", but no stnd. Nagios modul (this isn't
> > > good place for more explanation).
> > You're wrong. This is exactly the right place for more
> > explanation.
> > > Very short: Not concept "Event done then send message" but
> > predicitve-statistically: "EVENT PROBABLY
> > > is able to occur then send message".
> > You can get at this information without modifying the Nagios
> > core. If you still want this to run in the core of Nagios, a
> > far better way of achieving that is to write an eventbroker
> > module.
> > > Have I got your suport for this solutions?
> > That depends on what you mean by our support. I won't write
> > it for you, but if it turns out to be a nifty piece of code
> > I might use it for something and then ofcourse I'll send you
> > bugreports and patches.
> > > Are these solutions correct?
> > Since you haven't created the solutions yet, that's impossible
> > to tell.
> > > What is your opinions on this?
> > That you should refrain from altering the Nagios core if you
> > can manage by getting the required data from other places,
> > such as by loading a module or writing a log-parsing program.
> > > Thanks for reply
> > You're welcome.
> > > Note:
> > > Sorry, but I have very good reason for this short info - no detai=
l for more
> > info.
> > That sentence doesn't really parse. Anyway, you'll find it hard to =
get help
> > from the community while you're withhol
...[email truncated]...
