[Nagios-devel] Convert CHECK to SEARCH to avoid unnecessarily
--001636025c7c92af8d0474c030ae
Content-Type: text/plain; charset=UTF-8
Hi;
CVS delta 1.147 -> 1.148 includes un-dnl-ing some AC_CHECK_LIBS for USL/SVR=
4
-derivative Unix environments.
Note that the act of CHECK_LIBS (main) -- which is used to avoid having to
give an entry point/label -- is also replaced by the actual name of an entr=
y
point.
For details, see also:
http://www.gnu.org/software/autoconf/ma ... aries.html
The following change converts this Solaris edit to a SEARCH rather than a
CHECK, which works on all platforms, and only adds additional librarires if
the mentioned linker entry points are not already valid in the current list
of libraries:
--- configure.in.solaris 2009-09-30 00:48:17.000000000 +0100
+++ configure.in 2009-09-30 00:51:37.000000000 +0100
@@ -101,9 +101,8 @@
dnl Checks for library functions.
-AC_CHECK_LIB(nsl,main,SOCKETLIBS=3D"$SOCKETLIBS -lnsl")
-AC_CHECK_LIB(socket,socket,SOCKETLIBS=3D"$SOCKETLIBS -lsocket")
-AC_SUBST(SOCKETLIBS)
+AC_SEARCH_LIBS([getservbyname],[nsl])
+AC_SEARCH_LIBS([connect],[socket])
AC_CHECK_FUNCS(initgroups setenv strdup strstr strtoul unsetenv)
AC_MSG_CHECKING(for type of socket size)
Note: this also drops the need for "SOCKETLIBS" tracking. Libs add the nsl
(NameServices lib) and socket (yeah, socket) libraries only if the
pre-existing libraries (libc, libC, et al) don't already provde the lib.
This check is really intended for the merge-point where sockets moved from
being environmental things to in-kernel things, and not all executables
wanted to link with sockets included by default.
Please, someone on Solaris, consider this change, and check for me.
Allan
--=20
[email protected] "=E9=87=91=E9=B1=BC" http://linkedin.com/in/gold=
fish
Sent from Manchester, Eng, United Kingdom
Content-Type: text/html; charset=UTF-8
Hi;CVS delta 1.147 -> 1.148 includes un-dnl-ing some=
AC_CHECK_LIBS for USL/SVR4 -derivative Unix environments.Note that the act of CHECK_LIBS (main) -- which is used to avoid h=
aving to give an entry point/label -- is also replaced by the actual name o=
f an entry point.
For details, see also:h=
ttp://www.gnu.org/software/autoconf/manual/ht ... aries.html
The following change converts this Solar=
is edit to a SEARCH rather than a CHECK, which works on all platforms, and =
only adds additional librarires if the mentioned linker entry points are no=
t already valid in the current list of libraries:
--- configure.in.solaris 2009-09-30 00:48:17.0=
00000000 +0100+++ configure.in 2009-09-=
@@ -101,9 +101,8 @@=C2=A0=C2=A0=C2=A0=
dnl Checks for library functions.-AC_CHECK_LIB(nsl,main,SOCKETLI=
BS=3D"$SOCKETLIBS -lnsl")-AC_CHECK_LIB(socket,socket,S=
-AC_SUBST(SOCKETLIBS)+AC_SEARCH_LIBS([getservbyname],[nsl])=
+AC_SEARCH_LIBS([connect],[socket])=C2=A0AC_CHECK_FUN=
CS(initgroups setenv strdup strstr strtoul unsetenv)=C2=A0=
=C2=A0AC_MSG_CHECKING(for type of socket size)
Note: this also drops the=
need for "SOCKETLIBS" tracking. =C2=A0Libs add the nsl (NameServ=
ices lib) and socket (yeah, socket) libraries only if the pre-existing libr=
...[email truncated]...
