Re: [Nagios-devel] Addressing security vulnerabilities
On 11/27/2012 05:11 PM, Rudolph Pereira wrote:
> Hi all,
> I submitted http://tracker.nagios.org/view.php?id=400 a while ago and
> have had little to no response on it, even though it is a serious
> issue.
> I am looking for suggestions on how to deal with this; given the
> seriousness of the issue and how many users it affects I believe a
> security vulnerability notice should go out at the very least. Should
> I be working with ocert or some other intermediary on this?
Have you tested this exploit? It might be blocked by how NRPE handles
command line arguments.
One very simple way around it would otherwise be to disallow relative
paths to commands and use execve() to execute the checks. That way,
the plugin will get '$(lalafoo)' as an argument rather than the output
of that command.
OP5 AB www.op5.se
on peace.
