Joseph Hardeman wrote:
> Greetings,
> I see that there are 8 different ways to sort the status page. I want to be
> able to sort by Aliases.
> I have added a 9th way, SORT_ALIAS to the include/cgiutils.h and recompiled
> the cgis.
Exactly how did you do to add this to include/cgiutils.h without
modifying the sorting algorithm in status.c as well?
Do like this:
Download the nagios-2.0.tar.gz file to $HOME/patch
Run the following commands
$ cd $HOME/patch
$ tar xvzf nagios-2.0.tar.gz
$ mv nagios-2.0 nagios-2.0.patched
$ cd nagios-2.0.patched
Make your modifications to whatever files you did, and then do this:
$ cd $HOME/patch
$ diff -urN nagios-2.0 nagios-2.0.patched > nagios-sort-alias.diff
Send nagios-sort-alias.diff to this list and I'll have a look at it for you.
> I then modified the status.c to display the following lines:
> LINE 1554
> printf(" HREF='%s?type=%d&host=%s'>%s\n",host_status_bg_class,EXTINFO_CGI,DISPLAY_HOST_INFO,url_encode(temp_status->host_name),temp_host->alias);
> LINE 1999
> printf(" HREF='%s?type=%d&host=%s'>%s \n",status_class,EXTINFO_CGI,DISPLAY_HOST_INFO,url_encode(temp_status->host_name),temp_host->alias);
> (((Changed from temp_status->host_name to temp_host->alias)))
> This displays the Alias but it is still being sorted by host_name. When I
> checked all SORT_HOSTNAME to SORT_ALIAS I do not get an error, but it is
> still only sorting by hostname. What am I missing to get it to sort by host
> name.
Judging from your description; something fairly elementary. How much
C-code have you written earlier?
OP5 AB www.op5.se
