[Nagios-devel] RE: Missing TITLE tag for most (all?) images.
I was just about to report the same bug. Getting a plugin to act as a
workaround isn't the solution.
http://bugzilla.mozilla.org/show_bug.cgi?id=88297 has a good discussion
of this issue.
Alt text should only be used to give a text-users' representation of
images. Title should be used for verbose information for a graphical
browser. In nagios' situation, most of the time, the alt text could
probably double verbatim as title. On a normal website, having to use
extensive title text to make a site understandable would indicate poor
accessablity design, as it means the graphics aren't really providing
enough useful information. Nagios is definately not targeting visually
impared users, but it doesn't hurt to be somewhat accessible and
accomodate mozilla users. Especially when the change is pretty simple.
IE 6 is supposed to default to not show alt text, most people turn it on
right away, but some day that option might disappear. It wouldn't be the
first time microsoft has made a controverisal decision that forced
millions to change.
Mike
>On Mon, 2003-07-21 at 05:57, Randal, Phil wrote:
>> The easiest workaround is to install popupalt.xpi into
>> Mozilla / Firebird / Netscape 7.x.
>> http://white.sakura.ne.jp/~piro/xul/_popupalt.html.en
>Of course, that doesn't help if you support the idea that misuse of the
>alt tag subverts their uility for those who need the accessibility help.
>Karl
>> Cheers,
>> Phil
>> Phil Randal
>> Network Engineer
>> Herefordshire Council
>> Hereford, UK
>> > -----Original Message-----
>> > From: Markus Gaugusch [mailto:markus
> gaugusch.at ]
>> > Sent: 21 July 2003 10:45
>> > To: nagios-devel lists.sourceforge.net
>> > Subject: [Nagios-devel] Missing TITLE tag for most (all?) images.
>> > Hi,
>> > I'm using Mozilla and it does not display popup information
>> > for images, if
>> > there is no TITLE tag present. The ALT tag is (according to mozilla
>> > developers) the wrong place for popup information, although
>> > still widely
>> > used.
>> > Unfortunately lots of information is contained in the ALT tag
>> > and it would
>> > be sad if it is lost for mozilla users. The solution is to
>> > put the text
>> > into both tags (ALT and TITLE), because other browsers
>> > support only ALT.
>> > Markus
>> > PS: please CC: me for answers, I'm not on the list. Thanks!
>> > __________________ /"\
>> > Markus Gaugusch \ / ASCII Ribbon Campaign
>> > markus gaugusch.at X Against HTML Mail
>> > This SF.net email is sponsored by: VM Ware
>> > With VMware you can run multiple operating systems on a
>> > single machine.
>> > WITHOUT REBOOTING! Mix Linux / Windows / Novell virtual
>> > machines at the
>> > same time. Free trial click here: http://www.vmware.com/wl/offer/345/0
>> > _______________________________________________
>> > Nagios-devel mailing list
>> > Nagios-devel lists.sourceforge.net
>> > https://lists.sourceforge.net/lists/lis ... gios-devel
>> With VMware you can run multiple operating systems on a single machine.
>> WITHOUT REBOOTING! Mix Linux / Windows / Novell virtual machines at the
...[email truncated]...
