Hello
It's still problem with max plugin output length in 3.0b6. The increase
of max plugin output length cap from 4kb to 8kb was announce in Changelo=
g.
The maximum of output is defined by these constants in common.h nagios.h
NOTE: Plugin length is artificially capped at 8k to prevent runaway
plugins from returning MBs/GBs of data
back to Nagios. If you increase the 8k cap by modifying this value,
make sure you also increase the value
of MAX_EXTERNAL_COMMAND_LENGTH in common.h to allow for passive
checks results received through the external
command file. EG 10/19/07
#define MAX_PLUGIN_OUTPUT_LENGTH 8192 /* max length of
plugin output (including perf data) */
#define MAX_EXTERNAL_COMMAND_LENGTH 8192 /* max length of
an external command */
But the maximum length of message pushed to nagios through external
command file is limited to 4kb.
You can use this simple bash skript for test this bug.
#!/bin/bash
now=3D`date +%s`
commandfile=3D'/usr/local/nagios/var/rw/nagios.cmd'
host=3D'host'
service=3D'service'
string=3D'aaaaaaaaaaabbbbbbbbbbbcccccccccccdddddddddddeeeeeeeeeeeffffffff=
fffggggggggggghhhhhhhhhhhiiiiiiiiiiijjjjjjjjjjjkkkkkkkkkkklllllllllllmmmm=
mmmmmmmnnnnnnnnnnnooooooooooopppppppppppqqqqqqqqqqqrrrrrrrrrrrsssssssssss=
tttttttttttuuuuuuuuuuuvvvvvvvvvvvwwwwwwwwwwwxxxxxxxxxxxyyyyyyyyyyyzzzzzzz=
zzzzaaaaaaaaaaabbbbbbbbbbbcccccccccccdddddddddddeeeeeeeeeeefffffffffffggg=
gggggggghhhhhhhhhhhiiiiiiiiiiijjjjjjjjjjjkkkkkkkkkkklllllllllllmmmmmmmmmm=
mnnnnnnnnnnnooooooooooopppppppppppqqqqqqqqqqqrrrrrrrrrrrssssssssssstttttt=
tttttuuuuuuuuuuuvvvvvvvvvvvwwwwwwwwwwwxxxxxxxxxxxyyyyyyyyyyyzzzzzzzzzzzaa=
aaaaaaaaabbbbbbbbbbbcccccccccccdddddddddddeeeeeeeeeeefffffffffffggggggggg=
gghhhhhhhhhhhiiiiiiiiiiijjjjjjjjjjjkkkkkkkkkkklllllllllllmmmmmmmmmmmnnnnn=
nnnnnnooooooooooopppppppppppqqqqqqqqqqqrrrrrrrrrrrssssssssssstttttttttttu=
uuuuuuuuuuvvvvvvvvvvvwwwwwwwwwwwxxxxxxxxxxxyyyyyyyyyyyzzzzzzzzzzzaaaaaaaa=
aaabbbbbbbbbbbcccccccccccdddddddddddeeeeeeeeeeefffffffffffggggggggggghhhh=
hhhhhhhiiiiiiiiiiijjjjjjjjjjjkkkkkkkkkkklllllllllllmmmmmmmmmmmnnnnnnnnnnn=
ooooooooooopppppppppppqqqqqqqqqqqrrrrrrrrrrrssssssssssstttttttttttuuuuuuu=
uuuuvvvvvvvvvvvwwwwwwwwwwwxxxxxxxxxxxyyyyyyyyyyyzzzzzzzzzzzaaaaaaaaaaabbb=
bbbbbbbbcccccccccccdddddddddddeeeeeeeeeeefffffffffffggggggggggghhhhhhhhhh=
hiiiiiiiiiiijjjjjjjjjjjkkkkkkkkkkklllllllllllmmmmmmmmmmmnnnnnnnnnnnoooooo=
ooooopppppppppppqqqqqqqqqqqrrrrrrrrrrrssssssssssstttttttttttuuuuuuuuuuuvv=
vvvvvvvvvwwwwwwwwwwwxxxxxxxxxxxyyyyyyyyyyyzzzzzzzzzzzaaaaaaaaaaabbbbbbbbb=
bbcccccccccccdddddddddddeeeeeeeeeeefffffffffffggggggggggghhhhhhhhhhhiiiii=
iiiiiijjjjjjjjjjjkkkkkkkkkkklllllllllllmmmmmmmmmmmnnnnnnnnnnnooooooooooop=
ppppppppppqqqqqqqqqqqrrrrrrrrrrrssssssssssstttttttttttuuuuuuuuuuuvvvvvvvv=
vvvwwwwwwwwwwwxxxxxxxxxxxyyyyyyyyyyyzzzzzzzzzzzaaaaaaaaaaabbbbbbbbbbbcccc=
cccccccdddddddddddeeeeeeeeeeefffffffffffggggggggggghhhhhhhhhhhiiiiiiiiiii=
jjjjjjjjjjjkkkkkkkkkkklllllllllllmmmmmmmmmmmnnnnnnnnnnnoooooooooooppppppp=
ppppqqqqqqqqqqqrrrrrrrrrrrssssssssssstttttttttttuuuuuuuuuuuvvvvvvvvvvvwww=
wwwwwwwwxxxxxxxxxxxyyyyyyyyyyyzzzzzzzzzzzaaaaaaaaaaabbbbbbbbbbbcccccccccc=
cdddddddddddeeeeeeeeeeefffffffffffggggggggggghhhhhhhhhhhiiiiiiiiiiijjjjjj=
jjjjjkkkkkkkkkkklllllllllllmmmmmmmmmmmnnnnnnnnnnnooooooooooopppppppppppqq=
qqqqqqqqqrrrrrrrrrrrssssssssssstttttttttttuuuuuuuuuuuvvvvvvvvvvvwwwwwwwww=
wwxxxxxxxxxxxyyyyyyyyyyyzzzzzzzzzzzaaaaaaaaaaabbbbbbbbbbbcccccccccccddddd=
ddddddeeeeeeeeeeefffffffffffggggggggggghhhhhhhhhhhiiiiiiiiiiijjjjjjjjjjjk=
kkkkkkkkkklllllllllllmmmmmmmmmmmnnnnnnnnnnnooooooooooopppppppppppqqqqqqqq=
qqqrrrrrrrrrrrssssssssssstttttttttttuuuuuuuuuuuvvvvvvvvvvvwwwwwwwwwwwxxxx=
xxxxxxxyyyyyyyyyyyzzzzzzzzzzzaaaaaaaaaaabbbbbbbbbbbcccccccccccddddddddddd=
eeeeeeeeeeefffffffffffggggggggggghhhhhhhhhhhiiiiiiiiiiijjjjjjjjjjjkkkkkkk=
kkkklllllllllllmmmmmmmmmmmnnnnnnnnnnnooooooooooopppppppppppqqqqqqqqqqqrrr=
rrrrrrrrssssssssssstttttttttttuuuuuuuuuuuvvvvvvvvvvvwwwwwwwwwwwxxxxxxxxxx=
xyyyyyyyyyyyzzzzzzzzzzzaaaaaaaaaaabbbbbbbbbbbcccccccccccdddddddddddeeeeee=
...[email truncated]...
