Re: [Nagios-devel] Documentation Error - a case to use U
Dear Folks,
I am writing to thank you for your letters and say
On Tue, Sep 07, 2004 at 08:36:06AM +0100, Ben Clewett wrote:
> That's right, from A to C. Yes this will be a straight connecting line.
> I understand your feeling on this being miss-guided. But I see this
> information as a record of the latency of the plugin, not a check on
> whether there is a response. That is better taken care of by returning
> WARNING or CRITICAL from plugin exit code.
> In PerfParse I am toying with leaving a gap in the graph where a value
> is expected but not forthcomming, if the user selects some option.
> However this is difficult as the user may have changed the timeing of
> the plugin and the gap may be an expected response :)
> Either way, I would prefure to have no value, than to try and code a
> response for an infinite value.
> Unless the people who designed the plugin performance protocol want to
> give us some valid extensions for coding an infinite value, or coding a
> NULL value. Something like:
> | latency=INFms
> or
> | latency=NULLms
> But this is a better question for another news group, to which I'll make
> a posting now :)
Firstly, I haven't been paying much attention here so I prob should
desist but if the data is going in an RRD then isn't 'U' a reasonable
value because
1 plugin can always replace 'don't know' or nothing with 'U'
2 RRD deals with an 'unknown' value by interpolation. In this case,
however a 'U' is an NaN, which it also is able to deal with.
3 attempting to scale a large or small value is probably infeasable -
reading MAX and MIN values from the RRD is feasable in a plugin
class/framework environmnt which doesn't exist at the moment ...
Even after having considered again that a graph looks better with a max
latency in the case of no response, it still is wrong and bad to do so -
drop data such as this by Using U.
> Regards, Ben.
Stanley Hopcroft
Network specialist, IT Infrastructure
IP Australia
Ph: (02) 6283 3189 Fax: (02) 6281 1353
PO Box 200 Woden ACT 2606
http://www.ipaustralia.gov.au
