--------------040802090606050600060607
The daemon_dumps_core config option is really nifty (although redundant
since all systems with RLIMIT_* definitions have ulimit as well), but
unfortunately it's slightly broken. SIGSEGV is still handled by
sighandler, the daemon still does chdir("/") and non-daemon mode doesn't
dump core by default.
The attached patch takes care of it (and also sets it to TRUE by
default, a beta release should dump core if you ask me), and forces
coredumps if any of the DEBUG macros are defined, which is most likely
preferrable.
Cheers
OP5 AB www.op5.se
Lead Developer
name="nagios-coredump-fixes.diff"
Content-Disposition: inline;
filename="nagios-coredump-fixes.diff"
diff -urN ../nagios.orig/base/nagios.c ./base/nagios.c
--- ../nagios.orig/base/nagios.c Wed Jan 19 12:27:24 2005
+++ ./base/nagios.c Wed Jan 19 14:24:34 2005
@@ -149,7 +149,7 @@
int test_scheduling=FALSE;
int daemon_mode=FALSE;
-int daemon_dumps_core=FALSE;
+int daemon_dumps_core=TRUE;
int ipc_pipe[2];
diff -urN ../nagios.orig/base/utils.c ./base/utils.c
--- ../nagios.orig/base/utils.c Wed Jan 19 12:27:24 2005
+++ ./base/utils.c Wed Jan 19 14:56:22 2005
@@ -3235,7 +3235,10 @@
signal(SIGQUIT,sighandler);
signal(SIGTERM,sighandler);
signal(SIGHUP,sighandler);
- signal(SIGSEGV,sighandler);
+#if !defined(DEBUG0) && !defined(DEBUG1) && !defined(DEBUG2) && !defined(DEBUG3) && !defined(DEBUG4) && !defined(DEBUG5)
+ if(daemon_dumps_core==FALSE || daemon_mode==FALSE)
+ signal(SIGSEGV,sighandler);
+#endif
#ifdef DEBUG0
printf("setup_sighandler() end\n");
@@ -3380,7 +3383,11 @@
struct rlimit limit;
#endif
- chdir("/"); /* change working directory */
+ /* change working directory. scuttle home if we're dumping core */
+ if(daemon_dumps_core==TRUE)
+ chdir(getenv("HOME"));
+ else
+ chdir("/");
umask(S_IWGRP|S_IWOTH);
--------------040802090606050600060607--
