Andy Shellam wrote:
> Hi,
> I think I've found a bug in Nagios 3.0.2 with the contact_groups (and
> contacts) directive in service escalations.
> I have a contact group called "NetServe Support" which all my support
> personnel are a member of. In all other definitions (services, hosts
> etc), the following line works:
> contact_groups NetServe Support
It's not supposed to. If it works, it's an easter egg.
> But with a service escalation, it tries to expand that into two separate
> groups "NetServe" and "Support" despite the documentation saying that
> multiple groups should be separated by commas.
The documentation also says that the value referred to by the variable
contactgroup_name (which can't contain spaces) is the one to use when
referencing the contactgroup from other objects. I'm guessing you're
using the alias field instead, no?
OP5 AB www.op5.se
