Re: [Nagios-devel] timzones
--0016e6db7c6a56ed270464d73557
Content-Type: text/plain; charset=windows-1252
This is one of the new features of Centreon 2.1 (http://www.centreon.com )
which should be released very soon. Each contact will have his own GMT
settings, and different Nagios timeperiod configuration files will then be
generated as described by hemebond. The source code of the generation part
is available here :
http://svn.centreon.com/trunk/centreon/ ... onfigGene=
rate/genTimeperiods.php
Hope you're patient enough to look into it, otherwise you can still wait fo=
r
the beta release.
2009/3/11 Nick
> Could do but we cover 20 different times zones with DST=92s that need to=
be
> adjusted for 2 times a yr.
> Just thought it might have been easier and less likely to forget updating
> DST=92s
> Some need to be work hours others need to be out of hours, weekend,
> holidays it just gets large and messy
> Would need to have something near 100 different time configs
> Couldn't you just create 2 different "workhours" time config, relative to
> the Nagios server, then put the appropriate one on each contact?
> 2009/3/11 Nick
> Hello
> I have some hosts and services that the notifications need to be sent to =
2
> people ONLY during office hours
> The problem is that the 2 are in different world times zones
> Is I possible for a feature to be added to future versions for this
> Eg. In the contact config to add a variable as to what time zone the
> contact is in, relative to GMT
> Also to add a config file where can be added the start/end dates DST's fo=
r
> the various times zones
> Unless you programmers have a better way of doing this
> Many thanks in advance
> Nick
> Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
> powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
> easily build your RIAs with Flex Builder, the Eclipse(TM)based developmen=
t
> software that enables intelligent coding and step-through debugging.
> Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
> Nagios-devel mailing list
> [email protected]
t
> [email protected]
--=20
Sylvestre HO | Consultant
[email protected]
Tel. +33 (0)1 78 12 00 25
Mob. +33(0)6 37 37 62 67
MERETHIS est =E9diteur du logiciel Centreon.
Content-Type: text/html; charset=windows-1252
Hi,This is one of the new features of Centreon 2.1 (http://www.centreon.com=A0) which shou=
ld be released very soon. Each contact will have his own GMT settings, and =
different Nagios timeperiod configuration files will then be generated as d=
escribed by hemebond. The =A0source code of the generation part is availabl=
e here :=A0http://svn.centreon.com/trun=
k/centreon/www/include/configuration/configGenerate/genTimeperiods.php
Hope you're patient enough to look into it, otherwi=
se you ca
...[email truncated]...
