Ok,
This is not by any means done. In fact I'm only releasing it so that
Others can help. It is purely a developmental version right now!!
This _should_ be a drop-in replacement for the cgi's. Just drop this in
a htdocs directory (Not cgi-bin) that has nagios and php. It _should_
read
The default nagios.cfg file in /usr/local/nagios/etc/nagios.cfg.
If your nagios.cfg file is somewhere else, then change the value in the
file readconfig.php:
$config_file = '/usr/local/nagios/etc/nagios.cfg';
