I've set up a check_cluster service for processes running on 2 hosts, at
the same time I check the memory usage of those processes separately, so
when a process isn't running on 1 host, I don't want to send notifies
nor even actively check the memory usage. For that I defined service
dependencies like this:
define servicedependency{
host_name server100,server101
dependent_host_name server100,server101
dependent_service_description SwDocBatch Memory
inherits_parent 0
execution_failure_criteria c
notification_failure_criteria c
And indeed, it doesn't check nor notify when the process isn't running,
however, the service has come up long ago (as in it's in an OK state or
in a state other than c), yet it STILL doesn't check nor notify the
memory usage although it should. Now either this is a bug or I'm failing
at understanding the servicedependency function.
Here are the service definitions just in case they might be needed:
use inventory-service
host_name server101,server100
check_command
check_snmp_process!SwDocBatch.exe!0,1!0,1!
notifications_enabled 0
check_command
check_snmp_process!SwDocBatch.exe!0,1!-1,1! -m 100,150
name inventory-service
active_checks_enabled 1
passive_checks_enabled 1
parallelize_check 1
obsess_over_service 1
check_freshness 0
notifications_enabled 1
event_handler_enabled 1
flap_detection_enabled 1
failure_prediction_enabled 1
process_perf_data 1
retain_status_information 1
is_volatile 0
check_period 24x7
max_check_attempts 3
normal_check_interval 10
retry_check_interval 2
contacts inventory
notification_options c,r
notification_interval 1440
notification_period 24x7
register 0
Hindrek
