Re: [Nagios-devel] Nagios 3 Performance Monitoring
--nextPart56848063.Vc30vMWE5E
Content-Type: text/plain;
charset="iso-8859-15"
Content-Disposition: inline
Le Monday 29 October 2007 10:46:18 Hendrik B=E4cker, vous avez =E9crit=A0:
> Hi,
> Aaron Devey schrieb:
> > Hi Hendrik,
> > By any chance, are you using NDO utils? If so, do you see the same
> > results with NDO utils disabled?
> > Does the load/process count, on your machine increase at a similar rate
> > to your nagios latency?
> > There are also several settings in nagios.cfg that can cause degraded
> > nagios performance, depending on how they are tuned. Perhaps you could
> > make a copy of your nagios.cfg available for view? (with any
> > confidential information edited out, of course)
> > -Aaron
> Here it is:
I have good results with older version of Nagios with tis parameter:
check_result_reaper_frequency=3D2
Regards.
=2D-=20
C=E9dric Temple
Administrateur Syst=E8mes et R=E9seaux
Groupe Linagora
http://www.linagora.com
Content-Type: application/pgp-signature; name=signature.asc
Content-Description: This is a digitally signed message part.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
iD8DBQBHJa/5PG90bWBxbV4RAlf6AJ4q2uieP6AvwQMbAQWamg8jSOlcPACdHvpy
nJH/1FDovmFo0CxbLezzLUI=
=FuJx
-----END PGP SIGNATURE-----
--nextPart56848063.Vc30vMWE5E--
