Section Admin not working
diegosiassb
Post by diegosiassb »
Hello I reinstalled nagiosxi. I have a problem when I connect it to the web page everything works fine. When I go into Admin and I choose an item; Monitoring or Alerting or Commands or Templates does not display anything but error does not give even a blank page.
While if I go into Quick Tools I can see the pages and their contents. Can you help the installation went well
Diego
mguthrie
Re: Section Admin not working
Post by mguthrie »
Can you clarify which pages are not working? Is the Admin section, or is it the Configure->Core Config Manager area that is not working correctly?
If you're receiving error messages, can you post them? If you're just getting a blank page, access one of those pages, then run:
tail -20 /var/log/httpd/error_log
from a shell and send us that output.
We'll also need your Linux distro information for your new install.
diegosiassb
I solved.
I had not installed HTML_Template_IT-1.2.1.tgz.
Now everything works Thanks
Diego
rdedon
Post by rdedon »
Thank you for the update and please feel free to contact if you have any additional questions or issues.
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
