Re: [Nagios-devel] Passive checks number of ettempts error
--/9DWx/yDrRhgMJTb
Content-Type: text/plain; charset=iso-8859-1
Content-Disposition: inline
On Tue, May 08, 2012 at 12:07:05PM -0300, Rodney Ramos said:
> Hi everybody,
> I use Nagios, release 3.2.3, in a distributed environment, with a central
> server and several colector servers.
>=20
> For a long time I=B4m seeing errors on the passive check mechanism on the
> central server, as we can see below.
>=20
> Sometimes, on the central server, the states and number of attempts don=
=B4t
> follow the correct order, going from SOFT2 to HARD4, for example. However,
> on the colector server everything is OK.
>=20
> Log from Central Server:
> Host Up[2012-05-05 01:06:48] HOST ALERT: node;UP;HARD;1;TCP OK - 0.005
> second response time on port 135
> Host Down[2012-05-05 01:05:40] HOST ALERT: node;DOWN;HARD;4;CRITICAL -
> Socket timeout after 10 seconds
> Host Down[2012-05-05 01:04:16] HOST ALERT: node;DOWN;SOFT;2;CRITICAL -
> Host Down[2012-05-05 01:02:55] HOST ALERT: node;DOWN;SOFT;1;CRITICAL -
>=20
> Log from Colector Server:
> Host Up[05-05-2012 01:06:31] HOST ALERT: node;UP;SOFT;4;TCP OK - 0.005
> Host Down[05-05-2012 01:05:21] HOST ALERT: node;DOWN;SOFT;3;CRITICAL -
> Host Down[05-05-2012 01:04:01] HOST ALERT: node;DOWN;SOFT;2;CRITICAL -
> Host Down[05-05-2012 01:02:41] HOST ALERT: nodeDOWN;SOFT;1;CRITICAL -
You're losing updates. Given that it seems to be taking 15 or 20
seconds to get the update from your collector to your central server,
that's not hugely surprising. You don't say what the replication
mechanism is, but it either needs to get better at shovelling updates or
grow a bigger buffer, at a guess.
Cheers,
--=20
| Stephen Gran | Never eat anything bigger than your |
| [email protected] | head. |
| http://www.lobefin.net/~steve | |
--/9DWx/yDrRhgMJTb
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: Digital signature
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)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=BY7S
-----END PGP SIGNATURE-----
--/9DWx/yDrRhgMJTb--
