Re: [Nagios-devel] Feature Request
------=_Part_126629_21753608.1175541241025
Content-Disposition: inline
On 4/2/07, Anthony Mendoza wrote:
> I use the service or host downtime for the purpose you are using the
> "notification period" for and it works better
Thanks for the suggestion. We have tried this in the past and found that
recurring Scheduled Downtime skews Nagios' Availability report. It's my
understanding that Nagios won't check the host or service if it is in
scheduled downtime. Is this incorrect?
Also, what do you use for automating the scheduling of downtime? I've seen a
few tools available as add-ons but to my knowledge, Nagios doesn't
inherently support recurring downtime. Again, is that correct?
-David
Content-Type: text/html; charset=ISO-8859-1
the "notification period" for and it works better Thanks for the suggestion. We have tried this in the past and found that recurring Scheduled Downtime skews Nagios' Availability report. It's my understanding that Nagios won't check the host or service if it is in scheduled downtime. Is this incorrect?
Also, what do you use for automating the scheduling of downtime? I've seen a few tools available as add-ons but to my knowledge, Nagios doesn't inherently support recurring downtime. Again, is that correct?
-David
------=_Part_126629_21753608.1175541241025--
