Hendrik Bäcker wrote:
> Hi Antonio,
> Antonio Grassi schrieb:
>> Does this mean that notifications are sent only if the system is
>> configured to log notifications, or am I missunderstanding the code?
> I assume you were right. Regarding the sources the effectiv "my_system"
> call to execute the command is only available if "log_notifications" is
> true.
> I guess just moving the end of the if clause a few lines earlier should
> do the trick.
> I've attached a unified diff against the latest CVS code.
> Regards,
> Hendrik
Indeed - that's a pretty major bug. I'll get the patch applied and do
the same for the corresponding host notification function, which also
contains the bug.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
