[Nagios-devel] time_change_threshold is NULL
testing the 3.0.4 release revealed the following issue:
There is a new config parameter introduced, which has no default value in
the sample-config/nagios.cfg.in
> # TIME CHANGE ADJUSTMENT THRESHOLDS
> # These options determine when Nagios will react to detected changes
> # in system time (either forward or backwards).
> time_change_threshold=
which then results in
> Error in configuration file '.../nagios/nagios.cfg' - Line 1191 (NULL
> value)
Regards,
Sven
Sven Nierlein [email protected]
ConSol* GmbH http://www.consol.de
Franziskanerstrasse 38 Tel.:089/45841-439
81669 Muenchen Fax.:089/45841-115
