NRPE Plugins
diegosiassb
NRPE Plugins
Post by diegosiassb »
I installed nsclient + +. Exe in a windows server.
I can control process but I would also check the presence of a file.
I found the plugins ,but I do not know how you add on the remote server (client)
How do I add new plugins
In what directory I put my plugins?
Thanks Diego
rdedon
Re: NRPE Plugins
Post by rdedon »
Here is a lot documentation regarding various usage and configuration:
http://nsclient.org/nscp/wiki/doc/usage/nagios/nrpe
Hopefully should should help.
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
diegosiassb
Re: NRPE Plugins
Thanks.
I had already read the document that you have shown me.
But I do not understand how.
I Can not add a new check. can you help me? The problem is not central nagios but the configuration of server remote NRPE
My file NSC.ini
[modules]
NRPEListener.dll
NSClientListener.dll
NSCAAgent.dll
CheckWMI.dll
FileLogger.dll
CheckSystem.dll
CheckDisk.dll
CheckEventLog.dll
CheckHelpers.dll
;NSCLIENT++ MODULES
;# A list with DLLs to load at startup.
;  You will need to enable some of these for NSClient++ to work.
; * N O T I C E ! ! ! - Y O U   H A V E   T O   E D I T   T H I S *
;FileLogger.dll
;CheckSystem.dll
;CheckDisk.dll
;NSClientListener.dll
;NRPEListener.dll
;SysTray.dll
;CheckEventLog.dll
;CheckHelpers.dll
;CheckWMI.dll
; Script to check external scripts and/or internal a;liases.
;CheckExternalScripts.dll
; NSCA Agent if you enable this NSClient++ will talk to NSCA hosts repeatedly (so dont enable unless you want to use NSCA)
;NSCAAgent.dll
; LUA script module used to write your own "check deamon".
;LUAScript.dll
; RemoteConfiguration IS AN EXTREM EARLY IDEA SO DONT USE FOR PRODUCTION ENVIROMNEMTS!
;RemoteConfiguration.dll
; Check other hosts through NRPE extreme beta and probably a bit dangerous! :)
;NRPEClient.dll
; Extreamly early beta of a task-schedule checker
;CheckTaskSched.dll
[Settings]
;# OBFUSCATED PASSWORD
;  This is the same as the password option but here you can store the password in an obfuscated manner.
;  *NOTICE* obfuscation is *NOT* the same as encryption, someone with access to this file can still figure out the
;  password. Its just a bit harder to do it at first glance.
;obfuscated_password=Jw0KAUUdXlAAUwASDAAB
;# PASSWORD
;  This is the password (-s) that is required to access NSClient remotely. If you leave this blank everyone will be able to access the daemon remotly.
;password=secret-password
;# ALLOWED HOST ADDRESSES
;  This is a comma-delimited list of IP address of hosts that are allowed to talk to the all daemons.
;  If leave this blank anyone can access the deamon remotly (NSClient still requires a valid password).
;  The syntax is host or ip/mask so 192.168.0.0/24 will allow anyone on that subnet access
;allowed_hosts=127.0.0.1/32
;# USE THIS FILE
;  Use the INI file as opposed to the registry if this is 0 and the use_reg in the registry is set to 1
;  the registry will be used instead.
use_file=1
allowed_hosts=10.104.1.14,10.104.1.15
password=sianagios
; # USE SHARED MEMORY CHANNELS
;  This is the "new" way for using the system tray based on an IPC framework on top shared memmory channels and events.
;  It is brand new and (probably has bugs) so dont enable this unless for testing!
;  If set to 1 shared channels will be created and system tray icons created and such and such...
;shared_session=0
[log]
;# LOG DEBUG
;  Set to 1 if you want debug message printed in the log file (debug messages are always printed to stdout when run with -test)
;debug=1
;# LOG FILE
;  The file to print log statements to
;file=nsclient.log
;# LOG DATE MASK
;  The format to for the date/time part of the log entry written to file.
;date_mask=%Y-%m-%d %H:%M:%S
;# LOG ROOT FOLDER
;  The root folder to use for logging.
;  exe = the folder where the executable is located
;  local-app-data = local application data (probably a better choice then the old default)
;root_folder=exe
[NSClient]
;  This is a comma-delimited list of IP address of hosts that are allowed to talk to NSClient deamon.
;  If you leave this blank the global version will be used instead.
;allowed_hosts=
;# NSCLIENT PORT NUMBER
;  This is the port the NSClientListener.dll will listen to.
;port=12489
;# BIND TO ADDRESS
;  Allows you to bind server to a specific local address. This has to be a dotted ip adress not a hostname.
;  Leaving this blank will bind to all avalible IP adresses.
;bind_to_address=
;# SOCKET TIMEOUT
;  Timeout when reading packets on incoming sockets. If the data has not arrived withint this time we will bail out.
;socket_timeout=30
[NRPE]
;# NRPE PORT NUMBER
;  This is the port the NRPEListener.dll will listen to.
port=5666
;# COMMAND TIMEOUT
;  This specifies the maximum number of seconds that the NRPE daemon will allow plug-ins to finish executing before killing them off.
command_timeout=60
;# COMMAND ARGUMENT PROCESSING
;  This option determines whether or not the NRPE daemon will allow clients to specify arguments to commands that are executed.
allow_arguments=1
;# COMMAND ALLOW NASTY META CHARS
;  This option determines whether or not the NRPE daemon will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow_nasty_meta_chars=1
;# USE SSL SOCKET
;  This option controls if SSL should be used on the socket.
;use_ssl=1
;# BIND TO ADDRESS
; bind_to_address=
;  This is a comma-delimited list of IP address of hosts that are allowed to talk to NRPE deamon.
;allowed_hosts=
;# SCRIPT DIRECTORY
;  All files in this directory will become check commands.
;  *WARNING* This is undoubtedly dangerous so use with care!
;script_dir=scripts\
;# SOCKET TIMEOUT
;socket_timeout=30
[Check System]
;# CPU BUFFER SIZE
;  Can be anything ranging from 1s (for 1 second) to 10w for 10 weeks. Notice that a larger buffer will waste memory
;  so don't use a larger buffer then you need (ie. the longest check you do +1).
;CPUBufferSize=1h
;# CHECK RESOLUTION
;  The resolution to check values (currently only CPU).
;  The value is entered in 1/10:th of a second and the default is 10 (which means ones every second)
;CheckResolution=10
;# CHECK ALL SERVICES
;  Configure how to check services when a CheckAll is performed.
;  ...=started means services in that class *has* to be running.
;  ...=stopped means services in that class has to be stopped.
;  ...=ignored means services in this class will be ignored.
;check_all_services[SERVICE_BOOT_START]=ignored
;check_all_services[SERVICE_SYSTEM_START]=ignored
;check_all_services[SERVICE_AUTO_START]=started
;check_all_services[SERVICE_DEMAND_START]=ignored
;check_all_services[SERVICE_DISABLED]=stopped
[External Script]
;# COMMAND TIMEOUT
;command_timeout=60
;allow_arguments=1
;allow_nasty_meta_chars=1
;script_dir=c:\my\script\dir
[External Scripts]
;check_es_long=scripts\long.bat
;check_es_ok=scripts\ok.bat
;check_es_nok=scripts\nok.bat
;check_vbs_sample=cscript.exe //T:30 //NoLogo scripts\check_vb.vbs
;check_powershell_warn=cmd /c echo scripts\powershell.ps1 | powershell.exe -command -
[External Alias]
alias_cpu=checkCPU warn=80 crit=90 time=5m time=1m time=30s
alias_cpu_ex=checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
alias_disk=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
alias_service=checkServiceState CheckAll
alias_process=checkProcState $ARG1$=started
alias_mem=checkMem MaxWarn=80% MaxCrit=90% ShowAll type=physical
alias_up=checkUpTime MinWarn=1d MinWarn=1h
alias_file_age=checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%"
alias_file_size=checkFile2 filter=out "file=$ARG1$" filter-size=>$ARG2$ MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%"
alias_file_size_in_dir=checkFile2 filter=out pattern=*.txt "file=$ARG1$" filter-size=>$ARG2$ MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%"
alias_event_log=CheckEventLog file=application file=system filter=new filter=out MaxWarn=1 MaxCrit=1 filter-generated=>2d filter-severity==success filter-severity==informational truncate=1023 unique descriptions  "syntax=%severity%: %source%: %message% (%count%)"
alias_event_log2=CheckEventLog file=application file=system filter=new filter=in MaxWarn=1 MaxCrit=1 filter+generated=<2d "filter+eventSource==Service Control Manager" filter+severity==error truncate=1023 unique descriptions  "syntax=%severity%: %source%: %message% (%count%)"
check_ok=CheckOK Everything is fine!
; [includes]
;# The order when used is "reversed" thus the last included file will be "first"
;# Included files can include other files (be carefull only do basic recursive checking)
; myotherfile.ini
; real.ini
[NSCA Agent]
;# CHECK INTERVALL (in seconds)
;   How often we should run the checks and submit the results.
;interval=5
;# ENCRYPTION METHOD
;   This option determines the method by which the send_nsca client will encrypt the packets it sends
;   to the nsca daemon. The encryption method you choose will be a balance between security and
;   performance, as strong encryption methods consume more processor resources.
;   You should evaluate your security needs when choosing an encryption method.
; Note: The encryption method you specify here must match the decryption method the nsca daemon uses
\;       (as specified in the nsca.cfg file)!!
; Values:
;	0 = None	(Do NOT use this option)
;	1 = Simple XOR  (No security, just obfuscation, but very fast)
;   2 = DES
;   3 = 3DES (Triple DES)
;	4 = CAST-128
;	6 = xTEA
;	8 = BLOWFISH
;	9 = TWOFISH
;	11 = RC2
;	14 = RIJNDAEL-128 (AES)
;	20 = SERPENT
;encryption_method=14
;# ENCRYPTION PASSWORD
;  This is the password/passphrase that should be used to encrypt the sent packets.
;password=
;# BIND TO ADDRESS
;  Leaving this blank will bind to "one" local interface.
; -- not supported as of now --
;bind_to_address=
;# LOCAL HOST NAME
;  The name of this host (if empty "computername" will be used.
;hostname=
;# NAGIOS SERVER ADDRESS
;  The address to the nagios server to submit results to.
;nsca_host=192.168.0.1
;# NAGIOS SERVER PORT
;  The port to the nagios server to submit results to.
;nsca_port=5667
;# CHECK COMMAND LIST
;  The checks to run everytime we submit results back to nagios
;  Any command(alias/key) starting with a host_ is sent as HOST_COMMAND others are sent as SERVICE_COMMANDS
;  where the alias/key is used as service name.
[NSCA Commands]
;my_cpu_check=checkCPU warn=80 crit=90 time=20m time=10s time=4
;my_mem_check=checkMem MaxWarn=80% MaxCrit=90% ShowAll type=page
;my_svc_check=checkServiceState CheckAll exclude=wampmysqld exclude=MpfService
;host_check=check_ok
;# REMOTE NRPE PROXY COMMANDS
;  A list of commands that check other hosts.
;  Used by the NRPECLient module
[NRPE Client Handlers]
check_other=-H 192.168.0.1 -p 5666 -c remote_command -a arguments
;# LUA SCRIPT SECTION
;  A list of all Lua scripts to load.
;[LUA Scripts]
;scripts\test.lua
Diego
rdedon
Re: NRPE Plugins
Post by rdedon »
Immediately I see some misconfigurations that will need to be uncommented and/or values added/changed:
; Script to check external scripts and/or internal aliases.
;CheckExternalScripts.dll  UNCOMMENT THIS
;allowed_hosts=127.0.0.1/32 UNCOMMENT AND CHANGE
You may want to go through the whole file again and check all settings.
Rene deDon
Technical Team
___
