nagios 2009R1.9
Centos 5.4 VM image
I can't change the subject line for notification e-mails in the notify-host-by-service-by-email by prepending "[Nagios]" to the subject line
I change command using the Commands section of the nagiosxi GUI. I am not trying to change commands.cfg
after I apply my new configuration, it appears in the nagios/ect/commands.cfg
however, my alert e-mails are unchanged. please advise
Can't change subject line of emails in notify-host-by-email
Re: Can't change subject line of emails in notify-host-by-email
In NagiosXI the notifications are actually set up to be managed through the XI user settings, not so much the Core Config Manager.
XI notifications are primarily sent through the xi-host/service_notification_handler. The messages can be customized per user from the Configure->My Account Setting->Notification Message page.
so there is no way to customize for all users? This is a pretty important feature for my team
So here is my incredibly ugly hack, I hope you guys come up w/ a better way soon
[root@myserver /usr/local/nagiosxi/html/includes]# vi utils-email.inc.php
65: $mail->Subject="[NAGIOS] " . $opts["subject"];
Did you try adding your modified 'notify-host-by-email" command to the list of notification commands for your main contact template? That should allow you to do your system-wide custom notification. Go to the CCM->Contact->xi-contact-generic, and add the modified command to the list of host/service commands.
