Re: [Nagios-devel] coredumps
Andreas Ericsson wrote:
> > I think it's a mistake. Nagios drops privileges if ran by root.
> Yes, but it doesn't *need* root, so you can have it drop privs before
> even starting.
It's true, but misc examples run nagios directly by root, not doing 'su'.
> > Keeping in mind example above (HOME==/root), one might
> conclude that code
> > is inconsistent, and will never work without manual intervention.
> I know. I wrote that code in order to be able to run nagios
> in a debugging
> setup. I'm not complaining about changing it, I'm just very
> reluctant about
> not having a quick and easy way to override a setting that
> only root can
> change, and especially so when the option I want to override
> only has impact
> on debugging. Hence my suggestion to make this a config
> variable, preferrably
> overridable with a command-line option.
Well, there is different ways to solve the question.
Let it be your way, as long as it allows us to dump cores :-)
And it would be great to see some docs about right way to do it,
because it will eliminate mail threads like this one :-))
With best regards,
Andrew.
