Content-Type: text/plain; charset=WINDOWS-1252
Content-Disposition: inline
Now i'm getting confused too 8|
On Mon, Sep 15, 2008 at 5:13 PM, Marcel wrote:
> On Sat, Sep 13, 2008 at 5:22 AM, Hendrik B=8A=E4cker wrote:
>> Marcel schrieb:
>> > If you have a service that would be checked every 10 seconds, and
>> > notification interval =3D 60, then you should get the warning mess=
age.
>> > I think a bit and that would not be the case, but instead, not 10
>> > seconds, but like 300 (or five minutes if interval_length=3D1). Then t=
he
>> > warning is issued.
>> So, actual I'm a little bit confused about what is the fact.
>> You have service object with check_interval =3D 300 (seconds, cause
>> interval_length=3D1) and a notification_interval of 10 (seconds) or vice
>> versa?
> No, i have notification_interval's default value of 60 (minutes if
> interval_length=3D60), but when using itnerval_length=3D1 and
> normal_check_interval of 300 (seconds), then the warning message saying t=
hat
> my notification interval is lower than my command_check_interval appears =
at
> nagios.log
> check_interval =3D 300 +
>> notification_interval =3D 10
>> The warning message is IMHO OK cause it's useless to resend notification
>> cause of a service state that isn't able to change.
> That's what Nagios thinks aswell.
> Please drop us a short note what you are doing exactly.
> Notification_interval never gets multiplied by interval_length (nor
> divided), so it assumes interval_length =3D 60.
> Documentation says notification_interval is "time units", but never gets
> checked against interval_length, as command_check_interval is in line:
> 1344 command_check_interval*=3Dinterval_length;
> notification_interval never gets multiplied by interval_length, at least =
at
> config.c, then when using the default notification_interval of 60, and
> setting a 300s normal_check_interval (five minutes, because
> interval_length=3D1), then the sanity check at line 1878 prints the wrong
> warning message.
> My solution was to multiply (not assigning
> notification_interval*=3Dinterval_length), in config.c at check time, but=
that
> is wrong because it did not assign notification_interval*=3Dinterval_leng=
th,
> as command_check_interval is.
> Well, i did get rid of the wrong warning messages, but i think
> notifications would be messed up (i did not get into notifications.c to
> confirm anything).
> Anyone seeing messed up notifications with interval_length
> Regards,
> Marcel
I've realized some mistakes when trying to understanding what I've said
I was assuming a wrong premise of the notification_interval type. All the
time I was referring to notification_interval as not being
interval_length-based, but it is, so my whole assumption of the bug is
wrong.
But, notification_interval did not gets multiplied by interval_length as
command_check_interval is. So, from that point, if command_check_interval
and notification_interval are all the same 'time units', then i would expec=
t
notification_interval being assigned like command_check_interval
(command_check_interval*=3Dinterval_length).
Cheers,
Marcel
------=_Part_16688_7766264.1221511517738
Content-Type: text/html; charset=WINDOWS-1252
Now i'm getting confused too 8|On Mon, Sep 15, 2008 at 5:13 PM, Marcel <[email protected]> wrote:
=8A=E4cker <[email protected]<
...[email truncated]...
