Re: [Nagios-devel] Arguments to check commands
Don't use macros as arguments to commands at service definition. I
don't think this was ever documented in nagios 3 as beinf ok either
even if it worked. So try to see if this works:
command_name check_nrpe
command_line /usr/local/nagios/libexec/check_nrpe -H
$HOSTADDRESS$ $ARG1$
check_command check_nrpe!-c CheckEventLog -a
file=3DApplication \"filter=3Dgenerated gt -2d AND severity NOT IN
('success', 'informational')\" MaxWarn=3D1 MaxCrit=3D10
On Wed, Feb 27, 2013 at 5:59 AM, Ton Voon wrote:
> Hi,
> It seems like Nagios 4 has changed the way that check_command arguments a=
re parsed. Overall, this looks like a good thing as I think it looks easier=
to understand as it seems to be much more similar to how the shell would e=
valuate a command. However, I'm worried about the migration of existing Nag=
ios configurations.
> For instance, this worked in Nagios 3:
> define service {
> check_command check_nrpe!-H $HOSTADDRESS$ -c CheckEventLog -a=
file=3DApplication \"filter=3Dgenerated gt -2d AND severity NOT IN ('succe=
> define command {
> command_line /usr/local/nagios/libexec/check_nrpe $ARG1$
> In Nagios 4, this fails. To get the same result, you need to configure it=
as:
> define service {
file=3DApplication "filter=3Dgenerated gt -2d AND severity NOT IN ('succes=
s', 'informational')" MaxWarn=3D1 MaxCrit=3D10
> I can't quite understand the Nagios 3 rules versus the Nagios 4 rules or =
what the conversion process should be. Is there anything that is going to b=
e provided for Nagios 4 to ease migrating existing configurations?
> Ton
> Everyone hates slow websites. So do we.
> Make your web apps faster with AppDynamics
> Download AppDynamics Lite for free today:
> http://p.sf.net/sfu/appdyn_d2d_feb
> Nagios-devel mailing list
> [email protected]
