Re: [Nagios-devel] Event Profiler Timers?
>From: Andreas Ericsson [[email protected]]
>Sent: Wednesday, June 10, 2009 2:47 AM
>To: Nagios Developers List
>Subject: Re: [Nagios-devel] Event Profiler Timers?
>Steven D. Morrey wrote:
>>>> Would it be better (i.e. worth the overhead), to use clock_t =3D
>>>> clock() to get the entry and exit?
>>> Could be. But then we might as well use gettimeofday() from the
>>> start so the wrap-around case at least gets exercised a lot instead
>>> of every 72 minutes.
>>I don't follow you on that, can you elaborate on what you mean by the
>>wrap-around case and it being exercised, because I am not aware of it
>> and therefore have not taken it into consideration. My primary
>> reasons for wanting to use clock instead of gettimeofday were speed
>> and precision.
>Righto. clock(3) returns a value that represents seconds in 1/1000000
>"scale". This means that, for 32-bit architectures, it will wrap around
>every 71m 34.96s. Consider this:
>start =3D clock();
>do_stuff();
>end =3D clock();
>if (end /* wrapped around */
> delta =3D (end + (1 } else {
> delta =3D end - start;
>This might *look* right, but it really isn't. Some compilers can't
>store the intermittent value from the first case (which *will* wrap
>around once again), so it will get the result wrong, causing delta
>to end up as a huge number (clock_t can't be negative) and severely
>skewing the performance data. Since this will happen only for some
>compilers on some archs, and only every ~72 minutes, it will be
>pure hell to track down.
>Otoh, it might be worth doing something like this:
>clock_t start;
>double delta;
>start =3D clock();
>do_stuff();
>delta =3D clock_delta(start, clock());
>static double clock_delta(clock_t start, clock_t end)
> if (end > start) {
> /* normal case */
> delta =3D (double)(end - start);
> if (end /* wrap-around */
> delta =3D (double)(end + (1 delta -=3D (float)start;
> return delta / CLOCKS_PER_SEC;
>which should always provide the value as a fraction of seconds,
>which is almost certainly how you want to display it anyways.
This is fantastic information, and oddly enough explains a bug in a game se=
rver I once worked on, every hour and 15 minutes it would kick all the play=
ers out.
It was a truly nasty and annoying bug but now I know how and why it did it,=
so thanks for the excellent information.
>On a side-note, try to use arrays of doubles to store the total
>delta. It's much neater than having multiple global variables.
Yeah I'm going to make some changes to this and create a new profiler struc=
t that holds both the timer and the counter, then create an array of those =
using the event type as a key, it'll make maintaining and extending a lot e=
asier.
>The clock_delta function is also quite easily testable which
>alleviates the worries about the wrap-around case not being tested
>much.
Mind if I steal this code for something unrelated?
>> With gettimeofday we are talking about how much calendar time has
>> been spent, whereas with clock we are talking about how many ticks
>> were used by the program and then dividing that by clocks_per_second
>> to get a process time. I believe that clock would be more accurate
>> since it filters out the cost of other processes running on the
>> system.
>True, but the meaning of it would be hard to correlate against latency,
>since some events spend an inordinate amount of time switching contexts
>while others are fairly cpu-intensive but achieve a lot in wallclock
>time. Parsing passive check-results is CPU-intensive, but in wallclock
>time we can easily parse 50 or 100 of them in the same time it takes to
>fork and fire up a plugin. I'm not sure which of the values would be
>preferrable here, and I'm also not sure which of the processes gets the
>CPU-time attributed to it.
I really can't win for loosing with this one can I?
...[email truncated]...
