contrib/mini_epn.c | 8 +++++---
contrib/new_mini_epn.c | 6 ++++--
2 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/contrib/mini_epn.c b/contrib/mini_epn.c
index 598e239..1e4f72e 100644
--- a/contrib/mini_epn.c
+++ b/contrib/mini_epn.c
@@ -7,6 +7,8 @@
#include
#include "epn_nagios.h"
+#define MAX_INPUT_CHARS 1024
static PerlInterpreter *my_perl = NULL;
int main(int argc, char **argv, char **env) {
@@ -19,9 +21,9 @@ int main(int argc, char **argv, char **env) {
char *embedding[] = { "", "p1.pl" };
char *plugin_output ;
- char fname[64];
+ char fname[MAX_INPUT_CHARS];
char *args[] = {"","0", "", "", NULL };
- char command_line[80];
+ char command_line[MAX_INPUT_CHARS];
int exitstatus;
int pclose_result;
@@ -35,7 +37,7 @@ int main(int argc, char **argv, char **env) {
exitstatus=perl_run(my_perl);
- while(printf("Enter file name: ") && fgets(command_line, 80, stdin)) {
+ while(printf("Enter file name: ") && fgets(command_line, MAX_INPUT_CHARS-1, stdin)) {
SV *plugin_hndlr_cr;
STRLEN n_a;
int count = 0 ;
diff --git a/contrib/new_mini_epn.c b/contrib/new_mini_epn.c
index 4320111..a9fca50 100644
--- a/contrib/new_mini_epn.c
+++ b/contrib/new_mini_epn.c
@@ -12,6 +12,7 @@
#define DO_CLEAN "0"
@@ -60,7 +61,7 @@ void run_plugin(char *command_line) {
int count = 0 ;
int pclose_result;
char *plugin_output;
- char fname[128];
char *args[] = {"", "", "", "", NULL };
dSP;
@@ -231,7 +232,8 @@ int main(int argc, char **argv, char **env) {
* get_command_line calls Perl to get a scalar from stdin
- strncpy(command_line, get_command_line(), 128) ;
+ strncpy(command_line, get_command_line(), MAX_INPUT_CHARS-1) ;
+ command_line[MAX_INPUT_CHARS-1] = '\0';
/* Perl Term::ReadLine::readline() method chomps the "\n"
* from the end of the input.
1.6.4
