> [email protected] schrieb am 07.08.2008 13:37:24:
>> Than make the host check a "check_dummy!0!Host assumed to be up" pull
>> the plug on that host and enjoy the spam when your host goes down.
>> An an exercise, you can do the same on a router and it's 1,000 hosts
>> behind it, pull the plug on the router and watch your mail server melt
>> down as nagios starts sending 10,000 notifications at once
>> Seriously, hosts implement two type of dependencies:
>> 1. Service depend on the host being up
>> 2. Child hosts depend on parent host being up (will send UNREACHABLE
>> notifications instead of DOWN on child hosts, and those can be filtered
> out)
>> In most setups you will need at least one of these dependencies, so if
>> you remove host checks you will need another simple and obvious way to
>> define them. Do you have a suggestion for that?
> I think you seriously misunderstood him Thomas.
> He just suggested that we should drop the notation of hosts, services and
> such. As in real all they are is objects depending on each other. Yet the
> fact, that they have different names, makes things more complicated then
> needed and they put up several limitations.
> If you'd go over to a "pure object definition", it could look like this:
> (definition is simplified for easy of reading)
> define object {
> name coreswitch
> check check_icmp
> define object {
> name webserver01
> check check_icmp
> depending_on coreswitch
In which way is it depending on it? Is it depending on coreswitch to
be up and running, or should this "object" only return OK if coreswitch
is down?
> Right now the current host- and servicedefinition merely do the same
> "inside",
> yet nagios just tries to "simplify" things for us, so that we do not need
> to make
> services depending on their hosts - nagios does that for us.
> Sadly that also burdens us with some limitations, for example can't
> services
> be dependent on other hoststates.
True that, and in my book that's actually a good thing. Having one check
depend on a lot of different *hosts* is just godsdamn awful. You can
already make it depend on any number of services with the current syntax.
> If we would have simple object definitions, where we could freely choose
> all
> dependancies we want - Nagios would even be more powerful in my opinion.
You can already do that, using hostdependencies.
> Even better: it would be totally easy to build up hashtables with pointers
> for checking logics of depencies and such, as there is no need anymore
> to handle hosts and services different.
Hashes aren't all that efficient. They're just better than doing brute-force
full-text searches every time.
> It's all the same.
> There would be no more limitations of any kind, yet it of course makes
> things a little bit more complicated to configure.
Right, and what is 90-95% of the questions about on nagios-users?
> But with some standard templates that could easily be taken care of.
Show me, and I'll be convinced.
OP5 AB www.op5.se
