[Nagios-devel] several host notifications for 1 host
i get several notifications after a host went down even notification_interval is defined as 0. It seems to be related to service checks on these host because other hosts, without service checks, work fine. I know service checks will cause a host check but even then there shouldn't be a notification before the host check returns a hard state, right ?
Here are the important parts of a log.
[22-05-2007 15:02:35] HOST NOTIFICATION: mblum;server;DOWN;host-notify-by-email;(Host Check Timed Out)
[22-05-2007 15:02:35] HOST ALERT: server;DOWN;HARD;10;(Host Check Timed Out)
[22-05-2007 15:01:50] HOST ALERT: server;DOWN;SOFT;9;(Host Check Timed Out)
[22-05-2007 15:01:35] HOST NOTIFICATION: mblum;server;DOWN;host-notify-by-email;(Host Check Timed Out)
[22-05-2007 15:01:10] HOST ALERT: server;DOWN;SOFT;8;(Host Check Timed Out)
[22-05-2007 15:00:25] HOST ALERT: server;DOWN;SOFT;7;(Host Check Timed Out)
22-05-2007 14:59:40] HOST ALERT: server;DOWN;SOFT;6;(Host Check Timed Out)
[22-05-2007 14:59:35] HOST NOTIFICATION: mblum;server;DOWN;host-notify-by-email;(Host Check Timed Out)
[22-05-2007 14:58:55] HOST ALERT: server;DOWN;SOFT;5;(Host Check Timed Out)
[22-05-2007 14:58:15] HOST ALERT: server;DOWN;SOFT;4;(Host Check Timed Out)
[22-05-2007 14:57:35] SERVICE ALERT: server;DB server test egal;CRITICAL;HARD;1;(Service Check Timed Out)
[22-05-2007 14:57:35] SERVICE ALERT: server; DB server egal;CRITICAL;HARD;1;(Service Check Timed Out)
[22-05-2007 14:57:35] HOST NOTIFICATION: mblum;server;DOWN;host-notify-by-email;(Host Check Timed Out)
[22-05-2007 14:57:30] HOST ALERT: server;DOWN;SOFT;3;(Host Check Timed Out)
[22-05-2007 14:56:50] HOST ALERT: server;DOWN;SOFT;2;(Host Check Timed Out)
[22-05-2007 14:56:10] HOST ALERT: server;DOWN;SOFT;1;(Host Check Timed Out)
The notification at [22-05-2007 15:02:35] is right because after 10 checks the host check went into a hard state. But the ones before are a mystery for me. If its just a problem of misconfiguration i am sorry for posting here and thanks for a hint to fix this problem.
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
