Re: [Nagios-devel] Purpose of use_syslog
Hash: SHA1
Jon Angliss schrieb:
> On Mon, 1 Jun 2009 09:51:48 -0600, "Steven D. Morrey"
> wrote:
>> Hi Everyone,
>> I've decided to take a long hard look at my config files and have a question about some of the options.
>> In particular I'd like a little more information on the use_syslog option.
>> If enabled does this option use syslog instead of, or in addition to the internal log?
> Documentation doesn't make it entirely clear, but a quick peek into
> base/logging.c hints that use_syslog means it will log to both when
> set to 1, at least that's how I'm reading the code.
You are right with this.
use_syslog = 1 enables syslog loggin as an addition to the normal file
logging.
Hendrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (Darwin)
iEYEARECAAYFAkokxKwACgkQlI0PwfxLQjllBgCcDkXCmPqGAjNuZDRZc2pDodLJ
57QAmgLyhPFElKm4uHhkUoFLwobMbh5S
=reSu
-----END PGP SIGNATURE-----
