Re: [Nagios-devel] Nagios 3.0 RC2: Segmentation faults after
Christian Schneemann schrieb:
> And here some more background info:
> nagios is compiled with --enable-embedded-perl and embedded perl is
> deactivated in thte nagios.cfg.
> If I enable it in the nagios.cfg nagios runs fine without segfaulting. Do you
> have any ideas?
If you _enable_ ePN there is _no_ segfault??
As far as I see the segfaulting code segment has nothing to do
with/without ePN.
*confused*
Hendrik
