For each Windows hosts that i add to be monitored, I am getting a "unknown status" results and "check_nt: Could not parse arguments"
Can anyone explain?
Again I am new to Nagios configuration and I have looked over the instructions. I am using the sample config files.
Thanks in advance.
M
Windows hosts are returning unknown status results - check
- screen capture of unknown status and check_nt arguements error message
- check_nt.JPG (43.5 KiB) Viewed 4275 times
Re: Windows hosts are returning unknown status results - check
Can you post your objects.cache find, should be under /var some where.
Bzip2 is nice.
Bzip2 is nice.
Don't forget to remove any sensitive data with a find replace.
Hi MMestnik.mmestnik wrote:Can you post your objects.cache find, should be under /var some where.
Bzip2 is nice.
I am having a bit of trouble trying to locate the object.cache file
Hi MMestinik.
I found the problem.
I had s- PASSWORD present in my command.cfg file.
I removed the -s mypasswordgoeshere and the problem was resolved.
command_name check_nt
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -s mypasswordgoeshere -v $ARG1$ $ARG2$
Thank for your help.
