Re: [Nagios-devel] Nagios 3 Performance Monitoring
This is a cryptographically signed message in MIME format.
--------------ms020102020408070704010708
Content-Type: text/plain; charset=ISO-8859-1
Aaron Devey schrieb:
> Hi Hendrik,
> By any chance, are you using NDO utils? If so, do you see the same
> results with NDO utils disabled?
> Does the load/process count, on your machine increase at a similar rate
> to your nagios latency?
> There are also several settings in nagios.cfg that can cause degraded
> nagios performance, depending on how they are tuned. Perhaps you could
> make a copy of your nagios.cfg available for view? (with any
> confidential information edited out, of course)
> -Aaron
Here it is:
log_file=/usr/local/nagios/5/var/nagios.log
cfg_file=/usr/local/nagios/etc/checkcommands.cfg
cfg_file=/usr/local/nagios/etc/misccommands.cfg
cfg_file=/usr/local/nagios/etc/contactgroups.cfg
cfg_file=/usr/local/nagios/etc/contacts.cfg
cfg_file=/usr/local/nagios/5/etc/hostgroups.cfg
cfg_file=/usr/local/nagios/5/etc/hosts.cfg
cfg_file=/usr/local/nagios/5/etc/services.cfg
cfg_file=/usr/local/nagios/5/etc/servicegroups.cfg
cfg_file=/usr/local/nagios/etc/timeperiods.cfg
object_cache_file=/usr/local/nagios/5/var/objects.cache
precached_object_file=/usr/local/nagios/5/var/objects.precache
resource_file=/usr/local/nagios/5/etc/resource.cfg
status_file=/usr/local/nagios/5/var/status.dat
status_update_interval=10
nagios_user=nagios-5
nagios_group=nagios
check_external_commands=1
command_check_interval=15s
command_file=/usr/local/nagios/5/var/rw/nagios.cmd
external_command_buffer_slots=4096
lock_file=/usr/local/nagios/5/var/nagios.lock
temp_file=/usr/local/nagios/5/var/nagios.tmp
temp_path=/usr/local/nagios/5/tmp
event_broker_options=-1
log_rotation_method=d
log_archive_path=/usr/local/nagios/5/var/archives
use_syslog=0
log_notifications=1
log_service_retries=1
log_host_retries=1
log_event_handlers=1
log_initial_states=0
log_external_commands=1
log_passive_checks=1
max_service_check_spread=30
service_interleave_factor=s
max_host_check_spread=30
max_concurrent_checks=0
max_check_result_reaper_time=30
check_result_path=/usr/local/nagios/5/var/spool/checkresults
cached_host_check_horizon=30
cached_service_check_horizon=30
auto_reschedule_checks=1
auto_rescheduling_interval=30
auto_rescheduling_window=180
sleep_time=0.25
service_check_timeout=10
host_check_timeout=10
event_handler_timeout=30
notification_timeout=30
ocsp_timeout=5
perfdata_timeout=5
retain_state_information=1
state_retention_file=/usr/local/nagios/5/var/retention.dat
retention_update_interval=60
use_retained_program_state=1
interval_length=1
execute_service_checks=1
execute_host_checks=1
accept_passive_host_checks=1
enable_notifications=0
enable_event_handlers=1
process_performance_data=1
service_perfdata_file=/usr/local/nagios/5/var/service-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=30
service_perfdata_file_processing_command=process-service-perfdata-file-npcd-5
host_perfdata_file=/usr/local/nagios/5/var/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHE
...[email truncated]...
