Re: [Nagios-devel] Nagios 4 ignores object_cache_file and log_file
--00151758f2b8f9e94504ca2f70e4
Content-Type: text/plain; charset=ISO-8859-1
This did not fix CGIs, those would bypass trying to read main config file
and try to go directly for default cached objects file. This is
in xodtemplate_read_config_data and in addition to that issue macros are
wrong there with #ifdef NSCORE inside #ifdef NSCORE.
On Sun, Sep 16, 2012 at 2:32 PM, Andreas Ericsson wrote:
> On 09/16/2012 05:13 PM, Joerg Linge wrote:
> > Am 16.09.2012 um 16:27 schrieb Andreas Ericsson :
> >> Well, that's by design. The objects.cache should only be written to
> once.
> >> Or do you mean that it gets created but is empty?
> > Correct.
> > object_cache_file was created using the wrong path
> (/usr/local/nagios/var/objects.cache as defined in includes/locations.h
> instead of /omd/sites/ng4/var/nagios/objects.cache defined in nagios.cfg )
> > But the file contains just the header.
> Righto. I figured it out and a fix is pushed to both github and to
> svn. Thanks for helping out.
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Tel: +46 8-230225 Fax: +46 8-230231
> Considering the successes of the wars on alcohol, poverty, drugs and
> terror, I think we should give some serious thought to declaring war
> on peace.
> Everyone hates slow websites. So do we.
> Make your web apps faster with AppDynamics
> Download AppDynamics Lite for free today:
> http://ad.doubleclick.net/clk;258768047;13503038;j?
> http://info.appdynamics.com/FreeJavaPer ... nload.html
> Nagios-devel mailing list
> [email protected]
Content-Type: text/html; charset=ISO-8859-1
This did not fix CGIs, those would bypass trying to read mai=
n config file and try to go directly for default cached objects file. This =
is in=A0xodtemplate_read_config_data and in addition to that issue macros a=
re wrong there with #ifdef NSCORE inside #ifdef NSCORE.
On Sun, Sep 16, 2012 at 2:32 PM, Andreas Eri=
csson <=
> Am 16.09.2012 um 16:27 schrieb Andreas Ericsso=
n <[email protected]>:
>> Well, that's by design. The objects.ca=
che should only be written to once.
> Correct.
> object_cache_file was created using the wrong path (/usr/local/nagios/=
var/objects.cache as defined in includes/locations.h instead of /omd/sites/=
Andreas Ericsson =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 [email protected]
OP5 AB =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 www.op5.se
Tel: +46 8-230225=
=A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0Fax: +46 8-230231
on peace.
<div class=
...[email truncated]...
