Re: [Nagios-devel] New Feature: sorting of service- and hostnames
--------------050607090300060208020409
Content-Type: text/plain; charset=us-ascii; format=flowed
sorry, forgot the file
there it is, made from current cvs source...
Lars Volker schrieb:
> Hi,
> wouldn't it be nice if nagios respectively the status.cgi would be
> able to recognize, if two host- or servicenames are domain names,
> which means dot-separated (like blabla.foo.bar.org.uk) and then sort
> the list in an domain-aware kind of way?
> Example:
> current behaviour:
> a.x.org
> a.y.org
> b.x.org
> b.y.org
> desired behaviour
> a.x.org
> b.x.org
> a.y.org
> b.y.org
> I've written a few lines of code, implementing that feature, but i
> edited the source directly and have never worked with patching stuff.
> So if someone would like to explain, i'll provide a patch. Anyways the
> code is just about 9 lines long, simple hack only, but working. There
> also should be some kind of switch to toggle the behaviour.
> Thanks
> Lars
> This SF.Net email is sponsored by: Oracle 10g
> Get certified on the hottest thing ever to hit the market... Oracle
> 10g. Take an Oracle 10g class now, and we'll give you the exam FREE.
> http://ads.osdn.com/?ad_id=3149&alloc_id=8166&op=click
> Nagios-devel mailing list
> [email protected]
name="nagios.diff"
Content-Disposition: inline;
filename="nagios.diff"
diff -urN ../nagios-cvs.orig/cgi/status.c ./cgi/status.c
--- ../nagios-cvs.orig/cgi/status.c Wed Mar 24 06:22:03 2004
+++ ./cgi/status.c Wed Apr 28 15:40:39 2004
@@ -3899,7 +3899,7 @@
return FALSE;
else if(s_option==SORT_HOSTNAME){
- if(strcasecmp(new_svcstatus->host_name,temp_svcstatus->host_name)host_name,temp_svcstatus->host_name)host_name,temp_svcstatus->host_name)>0)
+ if(str_domain_compare(new_svcstatus->host_name,temp_svcstatus->host_name)>0)
return TRUE;
else
return FALSE;
@@ -4053,7 +4053,7 @@
return FALSE;
- if(strcasecmp(new_hststatus->host_name,temp_hststatus->host_name)host_name,temp_hststatus->host_name)host_name,temp_hststatus->host_name)>0)
+ if(str_domain_compare(new_hststatus->host_name,temp_hststatus->host_name)>0)
return TRUE;
else
return FALSE;
diff -urN ../nagios-cvs.orig/common/statusdata.c ./common/statusdata.c
--- ../nagios-cvs.orig/common/statusdata.c Thu Aug 28 06:07:36 2003
+++ ./common/statusdata.c Wed Apr 28 17:23:47 2004
@@ -178,6 +178,21 @@
#endif
+int str_domain_compare(char *name_a, char *name_b){
+ char *tmp_a, *tmp_b;
+ tmp_a = name_a + strlen(name_a) - 1;
+ tmp_b = name_b + strlen(name_b) - 1;
+ while ((tmp_a > name_a || tmp_b > name_b) && strcasecmp(tmp_a,tmp_b) == 0){
+ tmp_a--;
+ tmp_b--;
+ while ((tmp_a > name_a) && *(tmp_a)!=46 ) {tmp_a--;}
+ while ((tmp_b > name_b) && *(tmp_b)!=46 ) {tmp_b--;}
+ return strcasecmp(tmp_a,tmp_b);
@@ -348,7 +363,7 @@
/* add new host status to list, sorted by host name */
last_hoststatus=hoststatus_list;
for(temp_hoststatus=hoststatus_list;temp_hoststatus!=NULL;temp_hoststatus=temp_hoststatus->next){
- if(strcmp(new_hoststatus->host_name,temp_hoststatus->host_name)host_name,temp_hoststatus->host_name)next=temp_hoststatus;
if(temp_hoststatus==hoststatus_list)
hoststatus_list=new_hoststatus;
@@ -431,7 +446,7 @@
last_svcstatus=servicestatus_list;
for(temp_svcstatus=servicestatus_list;temp_svcstatus!=N
...[email truncated]...
