On 26 Jul 2005 at 8:29, Christian Theil wrote:
> Hi
> It seems the that the intention of cfg_dir is to include directories
> recursively, but that it is broken. The code is there in
> xodtemplate.c, but apparently buggy. If you change the line as
> indicated by the diff below it should work... (there are still some
> problems if you use symbolic links within your directory structure
> though).
> $diff xodtemplate.c ../../../tmp/nagios/xdata/xodtemplate.c
> 422c422
> > x=3Dstat(dirfile->d_name,&stat_buf);
> Best regards,
> Christian Theil Have.
> On 7/14/05, Dr. Dave Blunt wrote:
> > Unfortunately that's not what the 2.0 documentation says... From
> > http://nagios.sourceforge.net/docs/2_0/ ... ml#cfg_dir I
> > quote:
> > "This directive is used to specify a directory which contains object
> > configuration files that Nagios should use for monitoring. All files
> > in the directory with a .cfg extension are processed as object
> > config files. Additionally, Nagios will recursively process all
> > config files in subdirectories of the directory you specify here.
> > You can seperate your configuration files into different directories
> > and specify multiple cfg_dir=3D statements to have all config files in
> > each directory processed."
> > Note the reference 'recursively process all config files in
> > SUBDIRECTORIES of the directory you specify here'.
> > If that's a mistake then maybe the docs need to be updated but from
> > a look at the code, it seems like it *should* recurse directories
> > until it exhausts it's search for config files or runs out of
> > resources to do so.
> > -----Original Message-----
> > From: Subhendu Ghosh [mailto:[email protected]]
> > Sent: Thursday, July 14, 2005 9:49 AM
> > To: Dr. Dave Blunt
> > Cc: [email protected]
> > Subject: RE: [Nagios-devel] cfg_dir recursion not working
> > cfg_dir will not recurse into sub-dirs.
> > cfg_dir is used to read all "files" in the specified dir.
> > On Thu, 14 Jul 2005, Dr. Dave Blunt wrote:
> > > Indeed the files I want to include are all
> > > /usr/local/nagios/etc/rps/*/*.cfg. There are other files in those
> > > subdirs such as tar.gz files.
> > > It's SuSE ES 9 and /usr/include/dirent.h is present.
> > > Andreas Ericsson wrote:
> > >> I have an install with a number of Nagios configs files stored
> > >> under subdirectories:
> > >> /usr/local/nagios/etc/rps//acfgfile
> > >> /usr/local/nagios/etc/rps//anothercfgfile
> > >> /usr/local/nagios/etc/rps//yetanothercfgfile
> > > I suppose the files all match the glob(3) pattern
> > > Otherwise, that's possibly the issue right there.
> > >> There are no valid cfg files in /usr/local/nagios/etc/rps. All
> > >> services
> > > and
> > >> hosts are defined in the cfg files under , ,
> > >> etc.
> > >> When I define:
> > >> cfg_dir=3D/usr/local/nagios/etc/rps
> > >> in nagios.cfg the preflight check comes back with errors saying
> > >> it can't find any hosts or services.
> > > Are you running this on a Solaris or AIX platform? I think
> > > recursion only works on system that has the header
> > > file, and that one isn't present on all unices.
> > -sg
> > SF.Net email is sponsored by: Discover Easy Linux Migration
> > Strategies from IBM. Find simple to follow Roadmaps, straightforward
> > articles, informative Webcasts and more! Get everything you need to
> > get up to speed, fast.
> > http://ads.osdn.com/?ad_id=3D7477&alloc ... op=3Dclick
> > _______________________________________________ Nagios-devel mailing
> > list Nagios-devel@lists.
...[email truncated]...
