Dear Ladies and Gentlemen,
On FreeBSD RELENG 4 (4.9-RELEASE-p2), Nag 2.0a SEGVs with an error from
the reentrant C library (libc_r, FreeBSD 4.x threaded C library with at
least partial support for POSIX threads).
Details are :-
./configure --with-gd-inc=/usr/local/include/gd
--with-gd-lib=/usr/local/lib --enable-embedded-perl --with-perlcache
*** Configuration summary for nagios 2.0a1 11-18-2003 ***:
General Options:
Nagios executable: nagios
Nagios user/group: nagios,nagios
Command user/group: nagios,nagios
Embedded Perl: yes, with caching
Event Broker: yes
Install ${prefix}: /usr/local/nagios
Lock file: ${prefix}/var/nagios.lock
Init directory: /usr/local/etc/rc.d
Host OS: freebsd4.9
Web Interface Options:
HTML URL: http://localhost/nagios/
CGI URL: http://localhost/nagios/cgi-bin/
Traceroute (used by WAP): /usr/sbin/traceroute
External Data Routines:
Status data: Default (text file)
Comment data: Default (text file)
Downtime data: Default (text file)
Peformance data: Default (external commands)
Review the options above for accuracy. If they look okay,
type 'make all' to compile the main program and CGIs.
tsitc> make all
cd ./base && make
gcc -g -O2 -I/usr/local/include/gd
-I/usr/libdata/perl/5.00503/mach/CORE -DHAVE_CONFIG_H -DNSCORE -c
broker.c
nebmods.c
nebmods.c: In function `neb_add_module':
.. yada
-I/usr/libdata/perl/5.00503/mach/CORE -DHAVE_CONFIG_H -DNSCORE -o
nagiostats nagiostats.c -pthread -L/usr/local/lib -lm
cd ./cgi && make
-I/usr/libdata/perl/5.00503/mach/CORE -DHAVE_CONFIG_H -DNSCGI -c
getcgi.c
cgiutils.c
cgiauth.c
-I/usr/libdata/perl/5.00503/mach/CORE -DHAVE_CONFIG_H -DNSCGI -c -o
objects-cgi.o ../common/objects.c
xobjects-cgi.o ../xdata/xodtemplate.c
statusdata-cgi.o ../common/statusdata.c
xstatusdata-cgi.o ../xdata/xsddefault.c
-I/usr/libdata/perl/5.00503/mach/CORE -DHAVE_CONFIG_H -DNSCGI -pthread
-L/usr/local/lib -o avail.cgi avail.c getcgi.o cgiutils.o cgiauth.o
objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o
comments-cgi.o ../common/comments.c
xcomments-cgi.o ../xdata/xcddefault.c
downtime-cgi.o ../common/downtime.c
xdowntime-cgi.o ../xdata/xdddefault.c
-L/usr/local/lib -o cmd.cgi cmd.c getcgi.o cgiutils.o cgiauth.o
comments-cgi.o xcomments-cgi.o downtime-cgi.o xdowntime-cgi.o
-L/usr/local/lib -o config.cgi config.c getcgi.o cgiutils.o cgiauth.o
.. yada
*** Compile finished ***
If the main program and CGIs compiled without any errors, you
can continue with installing Nagios as f
...[email truncated]...
