Re: [Nagios-devel] $0 under ePN
--/04w6evG8XlLl3ft
Content-Disposition: inline
On Mon, Aug 21, 2006 at 02:48:19PM +1000, Gavin Carr wrote:
> 1. modify nagios to set an environment variable before it invokes=20
> the plugin (or ePN) containing the full path to the plugin
> e.g. NAGIOS_PLUGIN or some such
i think that within epn is probably the best place to fix this, since
it's only a problem from within epn.
i'm guessing that epn doesn't do fork/exec at all, so it would be
hard to "trick" the plugin by overwriting $0. perhaps what you
suggest would be a good approach wrt setting an environment variable
and doing some automatic setting in the perl plugin module.
sean
--/04w6evG8XlLl3ft
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: Digital signature
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (GNU/Linux)
iD8DBQFE6UyvynjLPm522B0RAgxlAJ9k77h+nVNyP2cxshgL6PcqBdVz0QCeM55I
CS4cHOeA3/Tt0STL8BosaSE=
=t6XS
-----END PGP SIGNATURE-----
--/04w6evG8XlLl3ft--
