Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Of course, I forgot the temp.cfg. sorry.
Jean
On Feb 2, 2008 7:32 PM, nap wrote:
> Hi list,
> I test a difficult sample (like your one Andreas). The test.cfg is the
> configuration file for nagios, and circular_check.png is a image of
> the configuration, and all the loops
> Red items are bad: the are in loops, green are OK. Red items need to
> be in error state, and just them. I realize my previous patch showed
> too much errors when a host was in 2 differents loops. Now It's OK.
> I change the output of my patch to fit exactly to the original output.
> You can use test.cfg and had some nasty parents relations, and see if
> the patch show all errors.
> Jean
> On Feb 1, 2008 11:44 AM, nap wrote:
> > Hi,
> > Here is the patch without the space. I just test it and it apply to
> > the cvs version.
> > I'll check for the object.cache and try to make mode funny samples
> > (I'll become a master of awk after that...). I think the exemple you
> > give will be ok with my algo (it's a standard algo for check graphs),
> > and we check a node one and only one time so no problem with
> > complexity I think. I'll post the sample, but if you already have some
> > special case, I take them
> > You can see the test.cfg. It's the sample with a loop. But it's a simple loop.
> > I'm ok with your conclusion, if the algo if false, it's useless
> > I'll work for big complex sample this week-end, if you don't post the
> > results monday, it's that i'm dead while reading the man of awk.
> > After that, I'll trace the services dependencies check.
> > Jean
> > > > nap wrote:
> > > >> Hi list,
> > > >> I finish my patch for the host path part. I try to folow the
> > > >> indentation and the coding style of nagios.
> > > > It looks a lot better now. For extra points, remove the hunks that
> > > > only insert whitespace changes.
> > > >> you can find test files with a lot of parent/childs at
> > > >> http://zegabes.free.fr/nagios/ .
> > > > What's lacking from that place is the objects.cache using the old
> > > > code and one generated using the new one, especially with multiple
> > > > parents, as well as a diff between them so one can see what, if any,
> > > > the differences are.
> > > I take that back. What's lacking is a proper test-case. If the config
> > > you've been using to test is the one on that site, you haven't even
> > > scratched at the funnier configs one sometimes see.
> > > For now, you're doing a "parent -> 100 children" thing, which is
> > > obviously quite quick and very simple to get correct values for.
> > > Will your algorithm work for something like this?
> > > parent2 parent8 ----------
> > > parent0 - parent3 - parent5 - parent6 - parent7 \
> > > parent4 parent9 - parent10 - endhost
> > > parent11-----------------------------------------------------------
> > > Which is indeed a rather messy and complex scheme, but something that
> > > nagios should handle (it does today, so it has to do so tomorrow too).
> > > Optimizing for speed in the simple (and probably most common cases) is
> > > all fine and good, but if things suddenly break horribly for 15-20% of
> > > the user-base, it isn't worth a thing.
...[email truncated]...
