--------------090006090600030604080408
I have been chasing the ndo2db segmentation fault and the program is
stopping at the funtcion ndo2db_db_init in the /* initialize table names
*/ part of the funciont in the source file db.c, where malloc get
executed. It stops on the first malloc.
I will try to find out why, but I am sharing this with the list,
maybe someone has already seen this.
Thanks.
Andreas Kasenides wrote:
> Alessandro Ren wrote:
>> Hello,
>> i've been trying to use ndoutils and I can no get nagios to dump
>> anything. The broker gets loaded and logs in nagios.log that has been
>> loaded, and either dumping in file or to a unix socket, I dont get
>> anything.
>> I've made some changes on the code to dump all logs to mysql by
>> myself already, but I'd like to use ndoutils, as they dump more
>> information and it'd be more complience for futures upgrades.
>> I am using nagios-2.0 stable release and tried ndoutis-1.2 and
>> ndoutils-1.3, the broker_module entry is in the nagios.cfg, it
>> creates de file ndo.dat and writes the start informantion but does't
>> dump anything.
>> Thanks.
>> __________________________________________________
>> *Alessandro Ren*
>> /*OpServices*/
>> /*Luciana de Abreu, 471 - Sala 403*/
>> /*Porto Alegre, RS - CEP 90570-060*/
>> *(* phone 55(51)3061-3588
>> *4* fax 55(51)3061-3588
>> *Q* mobile 55(51)8151-8212
>> *:* email [email protected]
> Alessandro,
> I think you are experiencing the same problem as I reported (see a few
> messages back) yesterday.
> I get similar results with you. When I enable debug mode in ndo2db I
> clearly see a Segmentation
> Fault coming from ndo2db after ti receives the start of operations
> from the broker module.
> I havent been able to track it down though. This is with v 1.2. Are
> you using Fedora Core 4?
> Anyone can help will be appreciated. Thanx.
> Andreas
> Andreas Kasenides
> Tel: +357 - 22892714
> e-mail: Andreas.Kasenides%at%cs.ucy.ac.cy
> (replace the %at% above with @)
*Alessandro Ren*
/*OpServices*/
Content-Type: text/html; charset=ISO-8859-1
is stopping at the funtcion ndo2db_db_init in the /* initialize table
names */ part of the funciont in the source file db.c, where malloc
get executed. It stops on the first malloc.
Thanks.
...[email truncated]...
