Re: [Nagios-devel] passive host - distributed monitoring
Hi,=20
My current scenario is that the central server can not reach the hosts =
that the distributed server is checking.
I tried using the method from the doc when I set the system up, but what =
I saw is that even if a service is "fresh", an active check is still =
made according to its schedule, and then it becomes unknown - stale,
Marco.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Hendrik =
B=E4cker
Sent: Saturday, April 14, 2007 11:27
To: Nagios Developers List
Subject: Re: [Nagios-devel] passive host - distributed monitoring
> one more thing, while working in distributed setup, i noticed that a
> service freshness checking is not don't if check_period is NONE, i =
think
> this is problematic, because if i disable active checks, the services
> will show as "Disabled" in the TAC, if i enable checks, it will run
> checks even if results are fresh, but my remote hosts are unreachable
> from the "master" nagios, I have a patch for it, if you think this is =
an
> issue, or maybe add a config option to "force freshness even if out of
> check_period"
Well, I think I don't get this right.
Your remote hosts are not reachable by your master? So active checks
will never be an option?
Why don't you go the way described in:
http://nagios.sourceforge.net/docs/2_0/distributed.html (nearly at the
end of the page)
This would get you an alerting when the passive checks are stale,
instead of doing a normal active check of your services when they are
stale.
> Thanks.
> Marco.
Kind regards
Hendrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.1 (MingW32)
=20
iD8DBQFGIJBwlI0PwfxLQjkRAlfTAJ98u1TLtH6OgGK3xWwD0amL54VL3QCfV4Vp
7EIJUAUioSapLRvSwQPt5RU=3D
=3DSCtK
-----END PGP SIGNATURE-----
Take Surveys. Earn Cash. Influence the Future of IT
Join SourceForge.net's Techsay panel and you'll get the chance to share =
your
opinions on IT & business topics through brief surveys-and earn cash
http://www.techsay.com/default.php?page ... ge&CID=3D=
DEVDEV
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
