Good day,
I am not sure if this helps you at all, but I've recently compiled a CVS
version on my RH 7.3 machine (Tuesday, I think) and I haven't had your
problems.
However:
- I used the .spec files to make RPMs.
- I didn't compile in MySQL support, although I probably should look
into that. =)
So, one might hypothesize that the problem is somehow related to the MySQL
support.
Darren Gamble
Planner, Regional Services
Shaw Cablesystems GP
630 - 3rd Avenue SW
Calgary, Alberta, Canada
T2P 4L4
(403) 781-4948
> -----Original Message-----
> From: Adams, Gavin [mailto:[email protected]]
> Sent: Thursday, May 23, 2002 1:12 PM
> To: [email protected]
> Subject: [Nagios-devel] CVS compile failing to run
> Hi,
> I noticed that my compiles of the recent CVS code (last week or so)
> compiles fine now, but fails to run as a daemon. The -v check
> runs fine,
> but when I try to startup Nagios, I'm getting a SIGEGV fault.
> What are some good debuggers that I could use to determine
> where in the
> code Nagios is giving me the finger? Here's the particulars on the CVS
> compile:
> Running this command:
> /usr/local/nagios/bin/nagios usr/local/nagios/etc/nagios.cfg
> seems to generate the proper response, but still stops after reviewing
> the schedules. However, if I try it as a daemon (-d), the
> last messages
> I get are:
> Completed circular path checks
> Completed circular service dependency checks
> Completed global event handler command checks
> Completed obsessive compulsive service processor command check
> [root@tempserver bin]#
> Followed by this message in the log file:
> [1022180415] Finished daemonizing... (New PID=6666)
> [1022180415] Caught SIGSEGV, shutting down...
> This is all on a RH 7.3 system, using the MySQL options. My configure
> options look like this:
> ./configure --with-mysql-lib=/usr/lib/mysql \
> --with-mysql-inc=/usr/include/mysql --with-mysql-xdata \
> --with-template-objects --with-template-extinfo --enable-DEBUG1
> The 1.0b1 code compiles, installs, and runs fine with the same set of
> .cfg files.
> Strangeness indeed. Is it possible there's been a schema
> change or some
> database corruption that is causing problems (although I've
> dropped the
> database and recreated)?
> Regards,
> --- Gavin
> _______________________________________________________________
> Don't miss the 2002 Sprint PCS Application Developer's Conference
> August 25-28 in Las Vegas -- http://devcon.sprintpcs.com/adp/index.cfm
> Nagios-devel mailing list
> [email protected]
