> Hi,
> Currently eventhandlers are executed in the main thread of nagios and block the core until the eventhandler is finished.
> Attached is a patch, which makes it possible for eventhandling neb modules to cancel/override the execution of eventhandlers.
> This is currently only possible with service and host checks. This patch would allow neb modules to stack eventhandlers on
> external queues or even distribute execution of eventhandler.
> This patch should not break the behavior of current neb modules, because their return value is currently ignored and
> execution of eventhandler will only be canceled on returning "NEBERROR_CALLBACKOVERRIDE".
Excellent patch. Thanks
I needed this for Merlin anyways, and now you saved me a days work. Is it
ok if I forge your Signed-off-by: line for the scm? I think some minor
mangling of the email text will make it usable as a commit message, so
I'll use that.
OP5 AB www.op5.se
on peace.
