This issue is presumably of no great consequence, but it ought=0Ato be fixe=
d along the way. I found it today while looking for=0Asomething else.=0A=
=0ABetween Nagios 3.3.0 and 3.3.1, certain lines got dropped from=0Abase/ch=
ecks.c, that made calls to delete_check_result_file().=0AHowever, there was=
also an accompanying log message that claims=0Athe check result file is de=
leted, and that log message was not=0Aalso removed. That message is now li=
ne 205 in base/checks.c=0Ain the 3.5.0rc1 release. It should now be remove=
d, as all=0Acheck result file deletion now appears be done only from within=
=0Abase/utils.c code. So if there is still a need for such a=0Amessage, it=
should be moved closer to where the file is=0Aactually deleted. If not, t=
he message can simply go away.=0A=0A--- On Thu, 2/28/13, Eric Stanley wrote:=0A=0A> From: Eric Stanley =0A>=
Subject: [Nagios-devel] Nagios Core 3.5.0rc1=0A> To: "Nagios Developers Li=
st" =0A> Date: Thursday, February 28, 2=
013, 3:59 AM=0A> Sorry for multiple release=0A> candidates, but I fixed two=
more issues with the CGIs that=0A> are very closely related to issues fixe=
d in the 3.4.5rc1=0A> tarball.=0A> =0A> The release has also been bumped to=
3.5.0 because of an ABI=0A> change. (It should have been bumped prior to 3=
.4.5rc1.) The=0A> downtime structure had a member added to help resolve the=
=0A> downtime notification problem. This means that modules will=0A> need t=
o be recompiled to use this version.=0A> =0A> You can download the 3.5.0rc1=
tarball from http://sourceforge.net/projects/nagios/ ... 3.x/nagio=
s-3.5.0/nagios-3.5.0rc1.tar.gz/download.=0A> =0A> Feel free to compile it a=
nd try it (on a test system,=0A> please). The 3.4.5 candidate did not gener=
ate much feedback=0A> and I'm hoping no news is good news. The changes betw=
een=0A> 3.4.5rc1 and 3.5.0rc1 are relatively minor, so I don't plan=0A> to =
wait long until releasing 3.5.0.=0A> =0A> The complete changelog since 3.4.=
4 is as follows:=0A> =0A> * Fixed bug #403: The "configuration" page of the=
webui=0A> doesn't use entity encoding when displaying the "command=0A> exp=
ansion" item (Eric Stanley)=0A> * Fixed bug #424: Nagios Core 3.4.4 seg fau=
lt (core dump) on=0A> restart after removing config for running service (Er=
ic=0A> Stanley)=0A> * Updated CGI utility functions to support UTF-8 charac=
ters=0A> (Eric Stanley)=0A> * Fixed bug where selecting Command Expansion f=
rom=0A> Configuration CGI page would display commands instead (Eric=0A> Sta=
nley)=0A> * Fixed bug #369: status.cgi crashes with segfault when=0A> there=
are german ulauts (=E4=F6=FC=DF) in the hostname or the=0A> servicename (E=
ric Stanley)=0A> * Fixed bug #418: Scheduled Downtime Notifications Resent =
On=0A> Nagios Restart/reload (Eric Stanley)=0A> =A0 =0A> =0A> -- =0A> Eric =
Stanley=0A> ___=0A> Developer=0A> Nagios Enterprises, LLC=0A> Email:=A0 est=
[email protected]=0A> Web:=A0 =A0 www.nagios.com=0A> =0A> =0A> -------------=
-----------------------------------------------------------------=0A> Every=
one hates slow websites. So do we.=0A> Make your web apps faster with AppDy=
namics=0A> Download AppDynamics Lite for free today:=0A> http://p.sf.net/sf=
u/appdyn_d2d_feb=0A> _______________________________________________=0A> Na=
gios-devel mailing list=0A> [email protected]=0A> https://=
lists.sourceforge.net/lists/listinfo/nagios-devel=0A>
