Re: [Nagios-devel] first_notification_delay for hosts
On 1 Dec 2005 at 12:33, Mathias Sundman wrote:
> On Thu, 24 Nov 2005, Andreas Ericsson wrote:
> > This patch adds a variable to the host object configuration,
> > first_notification_delay, which causes notifications for a host to be put off
> > until a minimum amount of time has passed.
> > This is intended to artificially mimic the service notification logic that
> > allows some time to pass between a detected error and the first notification
> > by forcing at least some "sleep-time" between the HARD detection of a downed
> > host and the first notification sent for it.
> > Because of how notifications are scheduled, this means that no host
> > notifications are sent unless the host has been checked first the
> > max_check_attempts times (run serially), waited until a service (or the host)
> > has been checked again and then, if the host is still down, the notification
> > is sent provided (first_notification_delay * interval_length) seconds has
> > passed.
> > I did the documentation update. All credits for the code should go to Mathias
> > Sundman, a Sungard employee and also a customer of ours who sent the patch to
> > me for review. I'm forwarding it to the list with his explicit consent. I've
> > tested it and found it to be in good working order.
> Ethan, do you think this patch has any chance of making it into Nagios
> 2.0?
> Just some background why I wrote this patch; Many of the hosts we monitor
> are such that we can accept them to lose network connectivity for some
> time (say 10-30 minutes), but if they go down permanently we want to be
> notified of this.
> To achieve this we had to setup a dummy notification group for the
> host, and then use escalations to be notified after a number of
> notification_intervals has elapsed. That solution had a number of
> drawbacks and felt more like a work around than a real solution.
> Then I searched the list archive and found a number of other people with
> the same problem as me but no other solution than the escalation method.
> So, I decided to but this patch together that works very well for us in
> our production environment atleast...
> Cheers // Mathias
Since this involves adding new functionality, I won't be adding it to
2.0. However, this is a great idea and patch, so I will be
committing it to CVS once I branch the 2.x code and starting working
on 3.0. I'll also be adding a similar option to delay the initial
notification time for services.
Ethan Galstad,
Nagios Developer
Email: [email protected]
