Re: [Nagios-devel] Nagios Tracker #15 - cannot access if logged in
On 15 Jul 2009, at 13:30, Christian Schneemann wrote:
> There will be some more "problems" with IDN domains I think. To ping
> such a
> domain you have to convert the domain with the idn tool.
> A ping from a shell would looke like this:
> ping `idn `
> So the problem is not just in this fix, maybe there work to be done
> on some
> other functions too to support IDN Domains in nagios.
> A short test with check_ping showed me, that there is no support for
> IDN
> Domains too.
I've closed the tracker item because there is no point in the Nagios
CGIs to allow that functionality if that backend tools will not work.
> So I would like to open a feature request for supporting IDN Domains.
Can I leave you to do this so that you will get updates. However, I
can't see it happening unless the tools are updated to allow IDN names
to work.
Ton
