Re: [Nagios-devel] [PATCH] Ndo 1.4b7 patch : SSL connexions
Hash: SHA1
nap schrieb:
> Hi,
> After 7 days of tests, I do not see any high utilisation of CPU of
> Load average. I use only one ndo connexion, but with 6000 services
> on it. So the SSL is quite ok with the CPU.
Nice to read this....
> I attach the cpu graph of the two last weeks of my nagios server
> (with ndomod and ndo2db on it).
Nice to see this... :)
> I put the patch in production 1 week ago.
Bad thing.
1. I wouldn't expect an error message like "NRPE: could not complete
ssl handshake" in NDO ;(
2. Patching the "Makefile"s wouldn't help, since they were build from
configure out of the "Makefile.in" files.
3. more things against the configure stuff
So please adjust your patches to correct the codeline which you get
from the NRPE stuff and rewrite them for NDO.
Eval the differrences between Makefile.in and the resulting Makefile
and do your changes in the "*.in" files
When you're done with this, please send the patch and I will review /
change it to be compatible with the autoconf stuff.
Regards
Hendrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (MingW32)
iD8DBQFJG/y0lI0PwfxLQjkRAjJQAJ4sTMvCmQIqnMcEd5H5C/2/MuvL6gCfYgnB
sefP8eRWpdos2SbThEh/214=
=eDnt
-----END PGP SIGNATURE-----
