[Nagios-devel] [PATCH] Segfault due to uninitialized data in
--------------070009090709090204060809
Attached is a patch that fixes some uninitialized service dependency
fields in the xodtemplate_duplicate_servicedependency function in
xodtemplate.c. This bug was triggered by a home-brew patch we had for
doing same-host service dependencies (which I've since decided to
discard in favor of William Leibzon's similar patch). I haven't been
able to come up with a configuration that triggers the segfault in a
virgin build of Nagios, but I figured I'd submit the patch here anyways
for consideration.
This patch applies to Nagios 2.5 and 2.6.
Jason Hoos
name="nagios-2.5-dup-servicedep-segfault.diff"
Content-Disposition: inline; filename="nagios-2.5-dup-servicedep-segfault.diff"
*** nagios-2.5/xdata/xodtemplate.c.orig2 Tue Oct 17 22:53:18 2006
--- nagios-2.5/xdata/xodtemplate.c Tue Oct 17 22:56:05 2006
*** 5069,5074 ****
--- 5069,5076 ----
new_servicedependency->dependent_hostgroup_name=NULL;
new_servicedependency->host_name=NULL;
new_servicedependency->dependent_host_name=NULL;
+ new_servicedependency->service_description=NULL;
+ new_servicedependency->dependent_service_description=NULL;
new_servicedependency->has_been_resolved=temp_servicedependency->has_been_resolved;
new_servicedependency->register_object=temp_servicedependency->register_object;
--------------070009090709090204060809--
