Re: [Nagios-devel] Checking for required elements
Shad L. Lords wrote:
> I've been noticing some strange behavior with nagios 3.0b checking for
> required elements. It appears that some of the checks aren't working as
> expected. I've been trying to determine when things aren't working so I can
> send some sample configs.
> When setting up some hosts I noticed that if I don't have a
> notification_period defined that it doesn't complain or give any warnings.
> In the documentation this field is listed as required.
The config verification should produce a warning. Its not a real error,
as Nagios will simply assume that any time is valid for
notifications/checks if a timeperiod isn't specified. The docs need an
update I guess.
> Also if I specify a host_groups and put in a hostgroup that doesn't exist I
> get an error right after "Reading configuration data..." but it then
> continues on. At the bottom it will show total error/warnings both at 0 and
> will still load.
I think the patch I just committed for the servicegroups error you
mentioned earlier also fixes this bug.
> Finally in trying to duplicate this I was trying to come up with a minimal
> config and found one that would cause a Segmentation fault during checking
> contacts. Here it is:
> define contact {
> contact_name test
> service_notification_commands command
> host_notification_commands command
> define command {
> command_name command
> command_line echo test
> define host {
> host_name host
> max_check_attempts 1
> define service {
> service_description service
> host_name host
> check_command command
> max_check_attempts 3
> Thanks for your great work,
> -Shad
I tested this tiny config and it worked okay - got warnings about
missing timeperiods and it didn't segfault. Try the latest CVS when you
get a chance to see if that fixes any problems you were having.
Ethan Galstad,
Nagios Developer
Email: [email protected]
