Re: [Nagios-devel] Antwort: [PATCH] - 3.0.3: only send out a
On Mon, Jul 20, 2009 at 3:33 AM, wrote:
> I don't think this is feasible, as it changes Nagios core
> functionality. I don't think I'm the only one wanting
> RECOVERY notifications even from WARNING states. If I define
> it that way, I expect it to behave that way.
My patch does that. If you specify:
define serviceescalation {
hostgroup_name nagios_hosts
contact_groups admins
first_notification 1 ; notify right away (1st notification)
last_notification 0 ; notify until service changes state
notification_interval 240 ; default to 4 hour re-notify
escalation_period 24x7
service_description .*
escalation_options u,w,r
register 0
Then you will get an escalation on warning, unknown, and recovery
escalations when then service returns from unknown OR warning (but in
the above case, *not* critical) to OK
If you put.
escalation_options u,r
register 0
You would only receive escalation notifications if the service goes
into an UNKNOWN state or recovers from an unknown state.
Does that clarify it? :)
So from what I hear from you it looks like my patch might fix the very
bug you are mentioning.
- Max
