Re: [Nagios-devel] Web NRPE
--------------040703070104030101060309
X-MIME-Autoconverted: from 8bit to quoted-printable by volkswagen.financial.com id h3GBbl820665
Ok,
but some comments. The out and err content is not properly quoted yet.=20
if the called plugin returns something containing to select the short=20
name given in webexec1.conf. -a '' to give arguments wich ar=20
passed as is to the plugin. also the xml-parsing is by now done with a=20
very simple-regex. i'm not shure if its really worth to install=20
xml-tools for such a simple response.
though it works ok for me i'm not very satisfied with this solution. a=20
much nicer way would be to have a http-transport for the original nrpe=20
(maybe transport-plugins for nrpe). then it would be easy to use=20
mod_proxy to talk to nrpe through apache.
please feel free to improve it :)
Chris
Hagen Deike wrote:
> Me too...
>=20
> Please post it here or send a link to download. Thanks a lot.
>=20
> =20
>=20
> Regards,
>=20
> Hagen Deike
>=20
> =20
>=20
> -----Urspr=FCngliche Nachricht-----
> *Von:* [email protected] [mailto:[email protected]]
> *Gesendet:* Dienstag, 15. April 2003 16:21
> *An:* [email protected]
> *Betreff:* [Nagios-devel] Web NRPE
>=20
> =20
>=20
>=20
> Chris,
>=20
> I would love to see that tool.
>=20
> Daniel Koffler
> [email protected]
> Tel: 514.497.1411
> Fax: 206.600.4642
> GPG Key ID: 0xA2C6DC83 Fingerprint: 1FD7 3FDF 8A0D 961F 26A2 3EDA AE8F=20
> A874 A2C6 DC83
>=20
--=20
financial.com AG
Maria-Probst-Stra=DFe 19 Tel.: ++49(0)89/318528-44
D- 80939 M=FCnchen Fax.: ++49(0)89/318528-28
name="check_remote.pl"
Content-Disposition: inline;
filename="check_remote.pl"
#!/usr/bin/perl
define();
getcmd();
my $result=abfrage_ausfuehren();
if ($result =~ /.*(.*).*(.*).*(.*)/ms) {
print STDOUT $2;
print STDERR $3;
exit $1;
} else {
print "$result\n";
exit $2;
# mein RequestAgent
sub define {
# ein paar http-objekte
use HTTP::Request;
use HTTP::Headers;
# include package for cmd-line-arguments
use Getopt::Std;
use LWP;
package RequestAgent;
@ISA =qw(LWP::UserAgent);
sub get_basic_credentials {
my($self, $realm, $uri) = @_;
return ($main::opts{'u'},$main::opts{'p'});
sub getcmd {
# hash mit optionen
%opts =(
u => 'username',
p => 'password',
l => 'http://www.myserver.com/tomcat/webexec1.jsp',
a => 'args',
c => 'command',
h => '0',
# welche optionen gibt es ?
getopts('u:p:l:a:c:h',\%opts);
# hilfe ausgeben
if ( $opts{'h'} ) {
print "Usage: $0 [ -u ] [ -p password ] [-a args ] [ -c command ] -l URL\n";
exit 1;
} # sub getcmd
sub abfrage_ausfuehren {
my $post_string="type=plain&args=".$opts{'a'}."&cmd=".$opts{'c'}."&mode=xml";
my $ua = RequestAgent->new();
my $header = HTTP::Headers->new();
$header->header('Content-Type' => 'application/x-www-form-urlencoded');
my $request = HTTP::Request->new('POST', $opts{'l'}, $header, $post_string);
my $response = $ua->request($request,\&callback);
if ($response->is_success) {
return $theline
} else {
return $response->status_line() ;
sub callback {
my($data, $response, $protocol) = @_;
$main::theline=$data;
name="webexec1.jsp"
filename="webexec1.jsp"
<%@ page import="java.io.*, java.net.*, java.util.*" session=
...[email truncated]...
